AV Sync error
thelangs
AV Sync error
Post by thelangs »
What does this mean?
AV sync issue in stream 1 at 0:06:14.720 with duration of 64ms : 2 frame(s) dropped to reduce audio skew to -0.002ms
Re: AV Sync error
It means that the data stream, when reconstructed from the pieces on the disk, had some overlapping audio frames.
forceawakens
Re: AV Sync error
Post by forceawakens »
I’m getting this error on every rip. It just started as of today. Will the rip play back correctly?
I haven’t changed any of my settings.
Re: AV Sync error
You can hide the error message, but if the values are small, I have not worried about it in the 5 or so years that they've been displayed.
They can have significance when dealing with hybrid audio like Atmos.
