No LibreDrive information shown?
Rander
Post by Rander »
So, I just managed to dump the MK-firmware into my Asus-drive, thanks to the Win10PE-iso I found in another thread. So, to check my other drives!
Odly, my Win10 machine doesn't show the LibreDrive section at all! I updated MakeMKV to 1.15.1, but no difference - the section is just missing!?
It is the same version that is running on my Linux (which I managed to update) and my Win7 (with an external drive which is not (yet) supported).
So, shouldn't there be a LibreDrive section anyway?
Re: No LibreDrive information shown?
Searching for "iHBS112 2" says this is a Lite-ON drive from ten years ago, so it is like my old 2009 LG drive - not LibreDrive capable, period.
Rander
Post by Rander »
Ah, fair enough. I just expected the section to be there, even if it did say "LibreDrive incapable". :-)
jonghotti
Post by jonghotti »
Happy to help you with a new LibreDrive compatible drive if needed. Contact information is below thank you.
