Lilo & Stitch fails to save
dash16
Post by dash16 »
I've tried this one a couple of times and have errored out pretty much the same way each time. Using LibreDrive v6 and a WH14NS40 with MK firmware in macOS 10.15.4.
MakeMKV v1.15.1 darwin(x64-release) started
Optical drive "BD-RE HL-DT-ST BD-RE WH14NS40 1.04d" opened in OS access mode.
Using LibreDrive mode (v06 id=F17C89187AE0)
Cells 34-end were skipped due to cell commands (structure protection?)
Title #1 was added (33 cell(s), 1:24:57)
Title #3 has length of 40 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3/1 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #3/2 has length of 2 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #4 has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #5 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #6 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #7 has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 19-end were skipped due to cell commands (structure protection?)
Title #8 was added (18 cell(s), 0:07:57)
Title #8/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #9 has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #10 has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #11 has length of 35 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #12 has length of 65 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #13 has length of 34 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #14 has length of 39 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #15 has length of 67 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #16 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #17 has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 2-end were skipped due to cell commands (structure protection?)
Title #18 was added (1 cell(s), 0:03:31)
Title #18/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #19 was added (1 cell(s), 0:03:36)
Title #19/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #20 was added (1 cell(s), 0:02:45)
Title #20/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #21 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #22 has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #23 was added (1 cell(s), 0:04:05)
Title #23/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #24 was added (1 cell(s), 0:03:04)
Title #24/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #25 was added (1 cell(s), 0:19:06)
Title #25/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #26 was added (1 cell(s), 0:02:58)
Title #26/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #27 has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #28 was added (1 cell(s), 0:02:34)
Title #28/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #29 has length of 67 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #30 has length of 66 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #31 has length of 63 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #32 has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33/2 has length of 27 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33/3 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33/5 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33/6 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #33/7 has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #34 has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #34/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #34/2 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #35 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #36 has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #37 has length of 82 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #38 has length of 100 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #39 has length of 85 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #40 was added (2 cell(s), 0:02:00)
Title #41 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Cells 8-end were skipped due to cell commands (structure protection?)
Title #42 was added (7 cell(s), 0:08:30)
Title #42/0/1 has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #43 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #44 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #45 has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #46 has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory /Users/dustinnewell/Movies/Plex/Movies/Lilo & Stitch (2002)
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '518000640'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk3' at offset '518000640'
Failed to save title 0 to file /Users/dustinnewell/Movies/Plex/Movies/Lilo & Stitch (2002)/title_t00.mkv
0 titles saved, 1 failed
Re: Lilo & Stitch fails to save
Your errors are consistent with a dirty disk. Have you read If you're experiencing rip errors, please read here first! yet?
dash16
Post by dash16 »
The disc is pretty scratched up, that could be it. I'll try some other methods of ripping it since the title seems to play in DVD players ok.
Ah, typical child-accessible optical disk.
One method I've used for getting disks like that to rip at least once is to clean and wax the surface using Pledge or similar furniture polish. It will dissolve the finger prints, fill in minor scratches, and you can often get at least one rip out of it. Spray on, rub in with a CLEAN finger, then wipe dry, going from the center of the disk to the rim. Make sure it is DRY before you put it in the drive.
If that doesn't work, a lot of video rental places stores (when you can find them) have disk resurfacing machines and (hopefully!) someone who knows how to use them. They'll polish off a surface layer to get rid of the scratches.
And there is always the alternative of renting it, ripping it, and use the original as proof of purchase if anyone gets bitchy about it.
Or, upgrade to the BD version, where you don't have to worry about interlaced video.
dash16
Post by dash16 »
Thanks for all the info! I was able to successfully rip with Handbrake + libdvdcss, but it was less than ideal compared to MakeMKV. Took about 45-60 minutes, when MakeMKV has been tearing through discs at 4-10 minutes each. LibreDrive v6 is awesome!!!
Fortunately in the stack of DVDs I'm going through, there have only been 3 or 4 like Lilo & Stitch that failed to rip, so I'm gonna go back to the others that failed and try Handbraking them too.
One thing to be aware of - handbrake is not intended for ripping. If you force it to with the third-party library you mentioned, and it hits any error, the rip will stop right there, and be judged successful. You might have only a portion of the video.
