flashing drive for Libredrive compatibility
martinbrady
Post by martinbrady »
Hello
I miss a way of doing this (hope my english good enough).
Do I just have to copy the .bin file for my drive model (Asus BC-12D2HT) obtained from the unzipped folder downloaded from the link given by Mike (mk-firmware-pack-20200415) and paste it inside the MakeMKV folder of my Program files (x86)?
then open and activate MakeMKV?
then being able to watch my brays in VLC or MPCHC?
as right now I have this:
Harware support: Yes
Firmware support: No
Firmware version: 3.01
and I think 3.01 is too old
Thanks a lot in advance!
please don't mention the quality of my english unless I'm obscure :wink:
Re: flashing drive for Libredrive compatibility
martinbrady wrote: Fri Jun 05, 2020 2:58 pm Hello
No follow my how to video for how to flash a drive here: viewtopic.php?f=16&t=19634
martinbrady
thanks a lot Billycar11
I will just look at that very carefully
cheers
martinbrady
:? Sorry Billy
but in the howto flash video you linked me, an .exe is used (at 35"), I think it's the drive self-update Mike is referring to
mikeadmin wrote:The images are very safe - you can't brick your drive if using "drive self-update" method.
but I only have this which is a .bin:
ASUS-BC-12D2HT-3.11-WM00300-211902271319.bin
downloaded/unzipped from the link he gave in his topic "Custom firmware pack with LibreDrive patches"
so I don't have an .exe I only have a .bin
I'm lost
think I will ask a remote flashing from one guy who knows... or if you would have something else (hey, I'm no geek)
thanks anyway
martinbrady wrote: Sat Jun 06, 2020 3:29 pm :? Sorry Billy
I'm lost
thanks anyway
The exe is the drive self update method email me if you want a remote flash
