Dolby Vision and 1.15.1
steffenmanden
Re: Dolby Vision and 1.15.1
Post by steffenmanden » Thu Jun 04, 2020 4:45 pm
SamuriHL wrote: Thu Jun 04, 2020 10:51 am Nice. Hopefully that happens soon and then things can continue moving forward. Thanks for the update!
The exoplayer pull is on pause untill the spec is done! it will be a quick fix however, as the proposed method is close to the current. Yusesope did a nice proof of concept where we just need to split it up into cleaner code - no point to do this before the spec is locked!
It will be there before you know it
Post by SamuriHL » Thu Jun 04, 2020 6:08 pm
steffenmanden wrote: Thu Jun 04, 2020 4:45 pm The exoplayer pull is on pause untill the spec is done! it will be a quick fix however, as the proposed method is close to the current. Yusesope did a nice proof of concept where we just need to split it up into cleaner code - no point to do this before the spec is locked!
I agree with that. Wait for the final spec to get approved and pull request merged, then it's off to the races. But we still need a MakeMKV update to drive content into the new MKV spec. As well as the player updates. Then it all needs to be tested. I can't wait.
Post by Coopervid » Thu Jun 04, 2020 7:11 pm
This development is great news! You surely remember how critical I was with all the workarounds with the MKV format regarding new audio and HDR formats. This is the right way. Make MKV ready for all of that in the MKV specs.
chrisandy
Post by chrisandy » Fri Jun 05, 2020 4:26 am
Post by SamuriHL » Fri Jun 05, 2020 11:42 am
Is it a shield tube or pro?
chrisandy
Post by chrisandy » Fri Jun 05, 2020 3:09 pm
Shield Pro.
SamuriHL wrote: Fri Jun 05, 2020 11:42 am Is it a shield tube or pro?
Post by SamuriHL » Fri Jun 05, 2020 4:05 pm
Should be playing back smooth. I know others have had issues previously but I don't remember what the cause was.
Post by shawnc22 » Fri Jun 05, 2020 4:46 pm
chrisandy wrote: Fri Jun 05, 2020 3:09 pm Shield Pro.
https://mega.nz/file/YSxhkSLK#fkfy54tYV ... xIOBZLyGR4
Give that sample a try. If it works with Atmos+DV, then something's wrong with your remux process. If you're still encountering playback issues, then it's something with your setup.
chrisandy
Post by chrisandy » Fri Jun 05, 2020 5:09 pm
shawnc22 wrote: Fri Jun 05, 2020 4:46 pm
Thanks very much. This worked fine.
I used the nightly TSMuxer to demux into the base + extra layer and yuescope's v4 tool to create the single layer, followed by TSMuxer again to create the .ts, however yuescope's v4 was GUI based so I didn't see a way to specify double vs single layer.
Just want to confirm if the issue could be lying with how I originally demuxed or how I created the single .hevc?
P.S. I also created a .m2ts file using the same muxing method and a few minutes in that has not given me any stuttering issues.
chrisandy
Post by chrisandy » Sun Jun 07, 2020 5:29 am
chrisandy wrote: Fri Jun 05, 2020 5:09 pm
Just want to add to this - I created a .ts file for another video using ffmpeg instead of TSmuxer to demux and created the rest of the files the same way. The resulting .ts file stutters, while the .m2ts does not. I tried hard wiring the Shield to rule out a network issue as well.
olevelo
Post by olevelo » Sun Jun 07, 2020 5:43 am
If you're using a Shield and Plex why are you making this so complicated? Makemkv, eac3to, tsmuxer, done.
NiCE77
Post by NiCE77 » Sun Jun 07, 2020 7:02 am
Angryunibrow wrote: Thu Apr 16, 2020 10:23 pm
olevelo wrote: Thu Apr 16, 2020 10:16 pm
1) Rip to MKV with MakeMKV
4) Remux to TS
Thanks for the command line for eac3to. Saves me the trouble of looking it up? Have you tried playing it in Kodi? I'd rather not have to use Plex as well.
Kodi does not play DV right now, need to use Plex on the shield.
Works with Kodi 19 alpha.
carrpet
Post by carrpet » Sun Jun 07, 2020 6:07 pm
olevelo wrote: Sun Jun 07, 2020 5:43 am
Will the Oppo UDP-203 handle DV and Atmos?
thetoad
Post by thetoad » Sun Jun 07, 2020 8:04 pm
carrpet wrote: Sun Jun 07, 2020 6:07 pm
In MKV? doubtful. as its doutful it will ever get a firmware update.
Epedemic
Post by Epedemic » Sun Jun 07, 2020 8:46 pm
NiCE77 wrote: Sun Jun 07, 2020 7:02 am
Not here? (0606 kodi 19 alpha, makemkv->tsmuxer files, which work in plex)
Fully expected though, as i don't expect anything new to work until the mkv work is done and standardized
