267 Versions on Disk
darkguy2
So I went to rip a copy of Knives Out today and found 267 versions of the movie on the disk. They are all around the same size with some a couple hundred MB larger then others and some with 16 chapters and other with 17. I tried to rip just the first one like I normally do and some of the scenes are out of order. Is there some way to tell which one is correct?
Re: 267 Versions on Disk
Lots of information available if you spend a moment or two looking at the forum and using the search function.
First link in the General section of the forum is What is the correct play list [insert title here]?
Searching for "knives" finds 116 messages discussing which is the correct version for DVD, BD, and UHD, in various countries.
