Star Trek TNG Season 2 Disk 5 can't save one episode
White
#1 Post by White » Wed Jun 03, 2020 12:21 pm
Hi all,
I'm currently ripping all of my movie and series DVDs and on some discs I have some trouble.
For Star Trek TNG Season 5 Disk 2 I only can save 3 of the 4 episodes of the disc.
When I insert the disc and use MakeMKV straight away I got this output:
MakeMKV v1.15.1 linux(x64-release) started
Debug logging enabled, log will be saved as /home/white/MakeMKV_log.txt
DEBUG: Code 101019395 at 59\D5CLED~UVu32XvH:213131778
DEBUG: Code 101019395 at 59\D5CLED~UVu32XvH:121261934
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'BD-RE TSSTcorp BDDVDW SN-506BB SB00' at offset '1048576'
Title #1 was added (8 cell(s), 0:43:34)
Title #2 was added (8 cell(s), 0:43:35)
Title #3 was added (8 cell(s), 0:43:28)
Title #4 was added (8 cell(s), 0:43:35)
DEBUG: Code 233 at b6fTHzsY8lO27qFuZLMHyFS/:0
Saving 4 titles into directory /home/white/Videos/EU_109552
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT FAILURE' occurred while reading '/VIDEO_TS/VTS_02_1.VOB' at offset '1857947648'
Error 'Posix error - Input/output error' occurred while reading '/dev/sr0' at offset '1857947648'
DEBUG: Code 1073741829 at 59\D5CLED~UVu32XvH:29394758
DEBUG: Code 100941313 at 59\D5CLED~UVu32XvH:29394758
DEBUG: Code 0 at ;cY(svt&WLA(:_v=!Q9(:29395402
DEBUG: Code 0 at 7W`9FE*W0I2ckUJ/ynF:213129915
DEBUG: Code 0 at ;cY(svt&WLA(:_v=!Q9(:29394459
DEBUG: Code 907201 at ;cY(svt&WLA(:_v=!Q9(:29393286
DEBUG: Code 0 at +o9A<E[~D\^R'e%nB ]:29396046
DEBUG: Code 0 at ku7g(Yx7:%;q<))^gYt\}:29400140
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 1 to file /home/white/Videos/EU_109552/title_t01.mkv
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT FAILURE' occurred while reading '/VIDEO_TS/VTS_03_1.VOB' at offset '0'
DEBUG: Code 0 at 7W`9FE*W0I2ckUJ/ynF:121265384
DEBUG: Code 0 at ;cY(svt&WLA(:_v=!Q9(:213130145
DEBUG: Code 0 at ;cY(svt&WLA(:_v=!Q9(:121262233
DEBUG: Code 0 at ;cY(svt&WLA(:_v=!Q9(:29393286
DEBUG: Code 0 at wG1vvZ2|_-zkYemmqJM:29393792
DEBUG: Code 0 at ku7g(Yx7:%;q<))^gYt\}:29399864
DEBUG: Code 0 at ku7g(Yx7:%;q<))^gYt\}:121268443
DEBUG: Code 0 at 3zf5*-%QoGe{\"q):213130559
DEBUG: Code 0 at 3zf5*-%QoGe{\"q):121262555
DEBUG: Code 0 at O,(wA#mM<}ZA6dFks0:121269708
DEBUG: Code 0 at O,(wA#mM<}ZA6dFks0:121270007
Failed to save title 2 to file /home/white/Videos/EU_109552/title_t02.mkv
Error 'Scsi error - HARDWARE ERROR:LOGICAL UNIT FAILURE' occurred while reading '/VIDEO_TS/VTS_04_1.VOB' at offset '0'
Failed to save title 3 to file /home/white/Videos/EU_109552/title_t03.mkv
Encountered 2 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
1 titles saved, 3 failed
But sometimes I also get an error during scanning for the titles that MakeMKV skipped one title because of logical errors or something like that (I tried tro repoduce this output today but with no success)
Does anyone have an idea what I can try to also copy the last title?
Re: Star Trek TNG Season 2 Disk 5 can't save one episode
#2 Post by Woodstock » Wed Jun 03, 2020 12:54 pm
There is nothing about this title that should prevent ripping (I've ripped it), but it looks like the disk is dirty, and the drive is trying too hard to read through that (the "off line" errors).
Start with cleaning it, as outlined in the "if you're having rip errors" topic in the Bluray forum.
White
#3 Post by White » Fri Jun 19, 2020 12:02 pm
I'm now cleaning all disks which I have failed to read out in the first run and try them again. Thanks for the adivce
