Need Help ripping 4K UHD
papacarter
Post by papacarter »
I have a LG BU40N that i purchased recently and have been trying to rip my discs using makemvk v1.15.1 on Win 10,64 bit, but no luck as I am getting the following error:
Error 'Scsi error - "ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED"
I have attached the log file for reference.
My drive details and log files are attached here.
Is there anything wrong I am doing? I have no issues ripping normal blu ray discs.
I appreciate your quick help, guidance and looking forward to hearing from you.
Ray
jonghotti
Re: Need Help ripping 4K UHD
Post by jonghotti »
Did you flash this drive with different firmware before you started ripping discs?
It looks like you did but i want to verify.
papacarter wrote: Wed Jun 03, 2020 9:12 am I have a LG BU40N that i purchased recently and have been trying to rip my discs using makemvk v1.15.1 on Win 10,64 bit, but no luck as I am getting the following error:
Ray
delete privtedata.tar and dont put libre drive v6 back in there you are having some compatibly issues stick with 5 for now
