Read Error Question
Jeffrey
Read Error Question
#1 Post by Jeffrey » Thu Dec 26, 2019 4:43 am
..., there is a fast and simple way to convert such copy into encrypted MakeMKV backup that can be opened by MakeMKV later. See our forum for details.
www.makemkv.com/errors/read/
Sorry for post but I can't for the life of me find directions on how to convert file that has been copied to my hard drive. Can someone point me in the direction of where this is in the forums?
wmcclain
Re: Read Error Question
#2 Post by wmcclain » Thu Dec 26, 2019 2:24 pm
Use the MakeMKV "Open File" menu selection.
For Blu-ray select the index.bdmv file.
For DVD, select video_ts.ifo.
-Bill
gerrimensch
#3 Post by gerrimensch » Mon Jun 01, 2020 3:19 pm
Hoi, me is having a simi prob :(
. .. and unfortunatelly theris no "index.bdmv file" .
only bdmv file . .. and using this one ends up with mkv telling: cannot open disc .
too bad, its about : matrix reloaded
-gerrimensch
#4 Post by Woodstock » Mon Jun 01, 2020 4:41 pm
Did MakeMKV create the folder structure? If so, there should be an index.bdmv file. If MakeMKV could not copy that file to the disk, it would have invalidated the whole backup.
Grauhaar
#5 Post by Grauhaar » Mon Jun 01, 2020 4:44 pm
only bdmv file . ..
BDMV is a folder!
Did you look into the BDMV folder? The index.bmmv is located there (in case of an MakMKV backup)
Good Luck :)
gerrimensch
#6 Post by gerrimensch » Tue Jun 02, 2020 7:55 am
THX for answers !!
guess i just copied the files to harddisc . ..
so i try again !
THX
