How to MKV Cars BD?
leftheaded
How to MKV Cars BD?
#1 Post by leftheaded » Sun Nov 21, 2010 9:26 pm
Has anyone been able to create a MKV from the Cars Blu-ray? Mine isn't working - the audio is jittery. And after some searching it seems this might be a disc that cannot be made into a MKV. Anyone?
crowfax
Re: How to MKV Cars BD?
#2 Post by crowfax » Mon Nov 22, 2010 12:27 am
MakeMKV does nothing to alter the audio track. The issue most likely lays with your choice of media player.
servocrow
#3 Post by servocrow » Mon Nov 22, 2010 7:43 pm
if you are trying to run it through Windows MEdia player then try another player, i.e. Splayer or Splash Lite.
if you get the same result then try re-ripping the BR with another app , like DVDFAB HD Decryptor, then convert to mkv with MAKEMKV
#4 Post by mike admin » Sat Nov 27, 2010 9:46 am
servocrow wrote:if you get the same result then try re-ripping the BR with another app , like DVDFAB HD Decryptor, then convert to mkv with MAKEMKV
This issue has nothing to do with a decryption.
