Could anyone please point me in the right direction to the correct LibreDrive firmware for my BRXL-PT6U2VB currently on BU10
its an external USB -> Buffalo BRXL-PT6U2VB EU Ultra thin Portable Blu Ray Writer
Current profile: DVD-ROM
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BU10
Serial number:
Firmware date: 2117-01-06 09:41
Bus encryption flags: 1F
Highest AACS version: 63
Firmware version: 0.BU10O
Am new to this sorry, and I am presuming its a BU40 but there are multiple versions of this?
Buffalo BRXL-PT6U2VB BU10 - Which LibreDrive Firmware?
Re: Buffalo BRXL-PT6U2VB BU10 - Which LibreDrive Firmware?
that is the correct firmware for libredrive. it is a BU40N inside.
are you having a problem with it? it should work as is
Ah that's good to know thank you, I wanted to future proof that was all and prevent any future automatic firmware updates. So best to stick with this than look to update at all?Billycar11 wrote: Mon Jun 01, 2020 7:49 am
yes leave it as is. and nothing will update the firmware automatically.c0alfield wrote: Mon Jun 01, 2020 7:59 am
but didn't you just buy this drive from someone on here likely me as i flash to that firmware for better compatibility with other rippers in that USB case.
as that drive normally comes with BN12 not BUxx or BU10 in your case
