Thank you - I was able to extract the video tracks by demuxing on TSmuxer. However, neither .hevc is carrying DV according to Mediainfo?
Dolby Vision and 1.15.1
Re: Dolby Vision and 1.15.1
If you're using the .bat file included with yusecope's tool, you have to edit it (open it in notepad or another text editor) and add -mode 2 to the end of the text line. You have also have to use the nightly version of tsmuxer, but the current latest nightly will give you a profile 8 video with a BL+RPU video track, which will not work on the ATV. You might want to do a little digging in the other thread for one that will give you profile 5.chrisandy wrote: Mon Jun 01, 2020 2:49 amThank you - I was able to extract the video tracks.
I fed them into the yuescope GUI (which did not give me the option to do -2) but once combined in TSMuxer, it loses Dolby Vision. Just to confirm, is the EL the smaller sized hevc of the two?
Thanks for clarifying - it seems when I demux initially via TSmuxer, both files (in .hevc format) lose Dolby Vision. Is there something I am missing? Furthermore, how can I tell which is BL v EL?shawnc22 wrote: Mon Jun 01, 2020 4:16 amIf you're using the .bat file included with yusecope's tool, you have to edit it (open it in notepad or another text editor) and add -mode 2 to the end of the text line. You have also have to use the nightly version of tsmuxer, but the current latest nightly will give you a profile 8 video with a BL+RPU video track, which will not work on the ATV. You might want to do a little digging in the other thread for one that will give you profile 5.chrisandy wrote: Mon Jun 01, 2020 2:49 amThank you - I was able to extract the video tracks.shawnc22 wrote: Mon Jun 01, 2020 2:20 am
eac3to, ffmpeg, or tsmuxer will help you extract out the video tracks.
Also, I'm assuming I want the end product to also be in the .hevc format?
MediaInfo will not recognize dolby vision in hevc format; these are raw video files. The BL file is the larger of the two files. The end product from yusecope's tool will be another hevc file that you will have to feed back into tsmuxer to get a TS or M2TS file as the end product.chrisandy wrote: Mon Jun 01, 2020 5:44 am Thanks for clarifying - it seems when I demux initially via TSmuxer, both files (in .hevc format) lose Dolby Vision. Is there something I am missing? Furthermore, how can I tell which is BL v EL?
Thanks - I've done that and created the M2TS. Mediainfo all checks out as expected (Dolby Vision, Atmos, etc) however Infuse on my ATV 4K is still only showing as HDR10...shawnc22 wrote: Mon Jun 01, 2020 6:05 amMediaInfo will not recognize dolby vision in hevc format; these are raw video files. The BL file is the larger of the two files. The end product from yusecope's tool will be another hevc file that you will have to feed back into tsmuxer to get a TS or M2TS file as the end product.chrisandy wrote: Mon Jun 01, 2020 5:44 am Thanks for clarifying - it seems when I demux initially via TSmuxer, both files (in .hevc format) lose Dolby Vision. Is there something I am missing? Furthermore, how can I tell which is BL v EL?
Thanks - I've done that and created the M2TS. Mediainfo all checks out as expected (Dolby Vision, Atmos, etc) however Infuse on my ATV 4K is still only showing as HDR10... I'm guessing this is because I didn't specify a profile. Is there a simple way to do that in TSMuxer?shawnc22 wrote: Mon Jun 01, 2020 6:05 amMediaInfo will not recognize dolby vision in hevc format; these are raw video files. The BL file is the larger of the two files. The end product from yusecope's tool will be another hevc file that you will have to feed back into tsmuxer to get a TS or M2TS file as the end product.chrisandy wrote: Mon Jun 01, 2020 5:44 am Thanks for clarifying - it seems when I demux initially via TSmuxer, both files (in .hevc format) lose Dolby Vision. Is there something I am missing? Furthermore, how can I tell which is BL v EL?
- Annotation 2020-05-31 232956.png (14 KiB) Viewed 32207 times
blackreign66
So far, I've determined that the .ts files with dolby vision and HD audio (atmos+dtsx) that I've created, work in Nvidia shield Pro with Plex and MxPlayer.
I own a Sony UBP-X700 and wanted to make you all aware that using the latest nightly build of TSMuxer and muxing into an M2TS container is the best approach. I had muxed many UHDs to the TS container and some of them experienced audio issues, especially those that had 7.1 TrueHD. Switched to M2TS and no problems occurred.
Using M2TS also keeps the HDMV descriptors in the file so you don't lose the PGS subtitles as well.
EDIT: This is if you are NOT using MakeMKV first. This would be if you are going directly from the UHD to a dual layer DV video file.
what audio issues did you get? What movie?ATD555 wrote: Tue Jun 02, 2020 10:23 pm I own a Sony UBP-X700 and wanted to make you all aware that using the latest nightly build of TSMuxer and muxing into an M2TS container is the best approach. I had muxed many UHDs to the TS container and some of them experienced audio issues, especially those that had 7.1 TrueHD. Switched to M2TS and no problems occurred.
I watched many DL DV TS with the x700 and I did not notice any issue. PGS subtitles also work.
The movie that had issues was "The Invisible Man", the English TrueHD audio track did not work in the TS container. TSMuxer does say that using the TS container you will lose the HDMV descriptors which can cause issues with Atmos audio tracks and PGS subs.RESET_9999 wrote: Wed Jun 03, 2020 2:15 amwhat audio issues did you get? What movie?ATD555 wrote: Tue Jun 02, 2020 10:23 pm I own a Sony UBP-X700 and wanted to make you all aware that using the latest nightly build of TSMuxer and muxing into an M2TS container is the best approach. I had muxed many UHDs to the TS container and some of them experienced audio issues, especially those that had 7.1 TrueHD. Switched to M2TS and no problems occurred.
In the latest nightly, including HDMV descriptors is off by default when choosing TS as the output. You can simply tick it back on if you want to include the descriptors in a TS file.ATD555 wrote: Wed Jun 03, 2020 2:23 pmThe movie that had issues was "The Invisible Man", the English TrueHD audio track did not work in the TS container. TSMuxer does say that using the TS container you will lose the HDMV descriptors which can cause issues with Atmos audio tracks and PGS subs.RESET_9999 wrote: Wed Jun 03, 2020 2:15 amwhat audio issues did you get? What movie?ATD555 wrote: Tue Jun 02, 2020 10:23 pm I own a Sony UBP-X700 and wanted to make you all aware that using the latest nightly build of TSMuxer and muxing into an M2TS container is the best approach. I had muxed many UHDs to the TS container and some of them experienced audio issues, especially those that had 7.1 TrueHD. Switched to M2TS and no problems occurred.
Any updates lately on where we're at with the new proposed mkv standard? Since yusecope was asked to hold off on any further work at least publicly things seem to not be progressing. At least that's the impression. Hopefully there's movement behind the scenes on getting everything finalized so the player guys can do their work.
Looks like they're just waiting on one last review:SamuriHL wrote: Thu Jun 04, 2020 3:44 am Any updates lately on where we're at with the new proposed mkv standard? Since yusecope was asked to hold off on any further work at least publicly things seem to not be progressing. At least that's the impression. Hopefully there's movement behind the scenes on getting everything finalized so the player guys can do their work.
https://github.com/cellar-wg/matroska-s ... n/pull/390
Nice. Hopefully that happens soon and then things can continue moving forward. Thanks for the update!
