Correct playlist for War of the Worlds 4k and bluray?
Unibrowser
Post by Unibrowser » Wed May 20, 2020 8:11 pm
4k Bluray shows
222.mpls
Segment count 1
Segment map 3
And
003.m2ts
Everything the same
1080p shows
020.mpls
Segment count 1
Segment map 55
And
001.mpls
Segment count 3
Segment map 74,55,73
This is the way
Krawk
Re: Correct playlist for War of the Worlds 4k and bluray?
Post by Krawk » Wed May 20, 2020 9:37 pm
This is a Paramount film, didn't think they used anything special to hide it.
jayper
Post by jayper » Thu May 21, 2020 12:18 am
Unibrowser wrote: Wed May 20, 2020 8:11 pm 4k Bluray shows
222.mpls
Segment count 1
Segment map 3
And
003.m2ts
Everything the same
1080p shows
020.mpls
Segment count 1
Segment map 55
And
001.mpls
Segment count 3
Only speaking to the UHD here: One is a playlist, and one is the m2ts file. They are different things but related. Playlists indicate which m2ts files should be played and in what order.
In this case, the playlist (222.mpls), includes the m2ts file (003). Look closely at the mpls file in the "Title Information" window. It lists 3 (003.m2ts) as the one and only item in the segment map. The way this disc was mastered was one long m2ts file for the entire movie. Which is why they look identical.
You want to rip the mpls as it includes the chapter markers, the m2ts file does not.
Hope that helps.
Unibrowser
Post by Unibrowser » Thu May 21, 2020 12:20 am
Ok thanks!
This is the way
omk1980
Post by omk1980 » Mon Jun 01, 2020 3:20 am
After i back up this disk, it's taking up the entirety of my 16:9 screen. It's weird bc most of my backups are letterbox/scope images.
Did i do something wrong?
