Dolby Vision and 1.15.1
chrisandy
Re: Dolby Vision and 1.15.1
#571 Post by chrisandy » Sun May 31, 2020 3:31 am
olevelo wrote: Sun May 31, 2020 1:29 am
chrisandy wrote: Fri May 29, 2020 4:29 pm Hi everyone,
I've spent a considerable amount of time going through this and other posts in this forum but am still running into some issues, so hoping someone can help me out.
I have a copy of a film that has the BDMV, CERTIFICATE and MAKEMKV folder.
The playlist with the Dolby Vision file is hidden, but I was able to locate it.
I have tried the following:
1. Using MakeMKV to create a .mkv file from the .index file within the BDMV folder
2. Using MakeMKV to create a .mkv file from the .mlps 'hidden' playlist file
3. Creating a .ts from both of the above, in addition to creating a .ts purely from the mlps.
In all of these instances, I am left with a HDR10 only file with no indication of Dolby Vision within Mediainfo.
I followed someone's suggestion on here and downloaded a more specific version of TSmux (4.06), and used that on the originally created .mkv file. This did show Dolby Vision in Mediainfo:
However, this:
1) Only played in HDR10 via ATV 4K Plex
2) Would not open the file when connecting to the LG directly via USB
3) Would not open the file when trying to play via LG Plex app
I then used the specific version of TSmux to create a .ts of the specific playlist .mpls file, with the following results in Mediainfo:
However, this .ts file is also not recognized via USB and it only plays in HDR10 on my OLED via the Plex app.
I've spent a lot of time on this so any help would be very appreciated
I don't think the LG Plex app can play DV ts files. Only mp4. In fact I haven't seen any Plex app other than on the Shield reported to play the ts files (I could very well have missed it though).
I have an LG C8, and a Shield with the Plex Server and a few DV ts files that I have played fine through the Shield's Plex app (with DV). I just tried watching through the LG Plex app and every one that I tried only triggered HDR10. These are all 04.06. So interesting that those wouldn't even play on your LG. I had previously tried profile 8 (I think...whatever version of tsmuxer I was using) and with those I would get audio but no video, as I recall.
Bottom line, currently for mkv/ts you need a Shield.
Thanks for clarifying, I appreciate it.
And just to clarify - it is a limitation of .mp4 that it can only carry AAC with DV, correct? So I basically have to choose between HDR10 + Atmos (or whatever Dolby variant) or DV + AAC?
#572 Post by shawnc22 » Sun May 31, 2020 6:28 am
chrisandy wrote: Sun May 31, 2020 3:31 am Thanks for clarifying, I appreciate it.
For MP4s, yeah pretty much. That's why TS/M2TS is used for DV+Atmos remuxing.
chrisandy
#573 Post by chrisandy » Sun May 31, 2020 6:41 am
shawnc22 wrote: Sun May 31, 2020 6:28 am For MP4s, yeah pretty much. That's why TS/M2TS is used for DV+Atmos remuxing.
That helps clarify - what is the best way to create a TS/M2TS that will carry both signals? Would DVDFab be able to do that working off of the original BDMV?
DaMacFunkin
#574 Post by DaMacFunkin » Sun May 31, 2020 7:09 am
However, this:
Hi, you can use ac3, DTS or DTS-HD in mp4.
As for TS on LG Plex app I’m pretty sure M2TS works with shield (2015,2017 also) as server, that’s what I mux all mine too (haven’t been to my server address for 9 weeks though because of lock down so can’t 100% confirm).
chrisandy
#575 Post by chrisandy » Sun May 31, 2020 7:26 am
DaMacFunkin wrote: Sun May 31, 2020 7:09 am
olevelo wrote: Sun May 31, 2020 1:29 am I don't think the LG Plex app can play DV ts files. Only mp4. In fact I haven't seen any Plex app other than on the Shield reported to play the ts files (I could very well have missed it though).
Thanks.
So just to reiterate:
The only way to get both Dolby Vision AND Atmos is via TS/M2TS however the only source capable of playing it is the Shield.
Regarding getting DTS/DTS-HD audio for MP4, what's the best way to go about doing that?
olevelo
#576 Post by olevelo » Sun May 31, 2020 3:36 pm
chrisandy wrote: Sun May 31, 2020 6:41 am
Makemkv, then use eac3to to extract the thd+a 3, then tsmuxer to convert to ts and add the audio back in. There's a post here somewhere with the exact command lines for eac3to.
Or just wait a couple weeks and we should have direct mkv support in at least exoplayer thanks to yusecope, once the new mkv standard is finalized and makemkv can get updated. (although still probably only good for shield)
chrisandy
#577 Post by chrisandy » Sun May 31, 2020 5:49 pm
olevelo wrote: Sun May 31, 2020 3:36 pm
Does Makemkv retain the Dolby Vision track?
Redhawk2000
#578 Post by Redhawk2000 » Sun May 31, 2020 6:17 pm
chrisandy wrote: Sun May 31, 2020 5:49 pm
Yes. But the mkv standard finalization is going to change the way that makemkv, once updated, stores the DV info. In other words, current rips that have DV would have to be redone to be be compatible with the upcoming standard.
chrisandy
#579 Post by chrisandy » Sun May 31, 2020 6:29 pm
Redhawk2000 wrote: Sun May 31, 2020 6:17 pm
Thanks - and I'm assuming this thread will get updated once that standard is released.
Just want to make sure I accurately summarize..
In order to get both Dolby Vision and Atmos via Plex you need
1)Nvidia Shield
2) The file:
a) MakeMKV of the BDMV
b) Extract Atmos audio via ea3to
c) Combine .mkv and extracted audio via TSmuxer to create a .ts
d) Use Plex via Shield to play .ts which will have both Dolby Vision + Atmos
Is this correct?
Also, is there no non-Shield way to get both? I'm assuming LG via USB wouldn't work?
Grencola
#580 Post by Grencola » Sun May 31, 2020 8:24 pm
chrisandy wrote: Sun May 31, 2020 6:29 pm Thanks - and I'm assuming this thread will get updated once that standard is released.
Yep.
chrisandy wrote: Sun May 31, 2020 6:29 pm Just want to make sure I accurately summarize..
1)Nvidia Shield
2) The file:
Is this correct?
Yep. But once the standard is finalized Plex should (hopefully) be one of the first to update their player, in which case you would just do a) then d) but it will be an mkv as ts will no longer be needed.
chrisandy wrote: Sun May 31, 2020 6:29 pm Also, is there no non-Shield way to get both? I'm assuming LG via USB wouldn't work?
Yep. LG can't passthrough lossless thd-atmos. An x700 or ATV 4K can work though. And probably the Ugoos AM6 Plus, too.
#581 Post by shawnc22 » Sun May 31, 2020 8:45 pm
Grencola wrote: Sun May 31, 2020 8:24 pm Yep. LG can't passthrough lossless thd-atmos. An x700 or ATV 4K can work though. And probably the Ugoos AM6 Plus, too.
The current gen ATV 4K (fingers crossed for next gen) is not going to work with that method. You'd have to use yusecope's tool to a create single layer (BL+RPU) file instead. Atmos will also be converted to PCM 7.1 in Infuse and not bitstreamed.
chrisandy
#582 Post by chrisandy » Sun May 31, 2020 9:05 pm
shawnc22 wrote: Sun May 31, 2020 8:45 pm
Thanks Shawn - is there an easily available link to yuescope's tool? I've seen mentions of it in previous pages. Is it as simple as using that tool to generate the resulting file? And would I still be able to use Plex via the current gen ATV 4K or would I need to use Infuse instead?
#583 Post by shawnc22 » Mon Jun 01, 2020 12:38 am
chrisandy wrote: Sun May 31, 2020 9:05 pm
https://makemkv.com/forum/viewtopic.php ... 413#p85413
Use the tool with -mode 2, and you will get a BL+RPU file after feeding in the extracted BL and EL tracks. There is a version of tsmuxer you can use to then get a profile 5 (the only profile that ATV supports) video, but I'm not sure which exact version it is. Maybe @Angryunibrow can help you with that as he's been creating a lot of remuxes for the ATV. You will also have to use Infuse as I don't believe Plex supports the Atmos -> PCM 7.1 conversion. Note that when you go through this method with titles that have a full enhancement layer, you are discarding that entire layer and the resulting DV video might not be fully accurate.
chrisandy
#584 Post by chrisandy » Mon Jun 01, 2020 1:52 am
shawnc22 wrote: Mon Jun 01, 2020 12:38 am
Amazing. Many thanks. Hopefully last dumb question but how do I extract the BL and EL tracks?
#585 Post by shawnc22 » Mon Jun 01, 2020 2:20 am
chrisandy wrote: Mon Jun 01, 2020 1:52 am Amazing. Many thanks. Hopefully last dumb question but how do I extract the BL and EL tracks?
eac3to, ffmpeg, or tsmuxer will help you extract out the video tracks.
