Failure converting Open Season 2
HakanL
Post by HakanL » Fri May 29, 2009 1:44 am
I run into a problem using MakeMKV on the Open Season 2 DVD. I ripped it with DVD Decryptor and AnyDVD to an iso (I tried straight from MakeMKV as well, same issue). I get the attached errors and it's not converted. Btw, wouldn't it make sense to have the log window so you can copy/paste from it?
Re: Failure converting Open Season 2
Post by mike admin » Fri Jun 05, 2009 7:40 am
The error says that VOB file is incorrect. Normally, one can copy data from the log window but this functionality was accidentally broken in 1.4.2. How soon this error happens after you press the "save" button?
HakanL
Post by HakanL » Sat Jun 06, 2009 12:34 am
About 2 minutes into the copy process. The progress bar is at 100%.
HakanL
Post by HakanL » Sat Jun 06, 2009 12:41 am
As a test I also ran it thru DVD Shrink, stripping the non-English languages but without re-encoding. It went thru fine, but when I then tried to open the resulting ISO in MakeMKV then I got the same error.
Post by mike admin » Tue Jun 09, 2009 6:05 am
This is probably disc-specific issue. We'll investigate.
