BD Java - not recognized in Java RE
TheSound
#1 Post by TheSound » Fri May 29, 2020 6:03 pm
Dear all,
i get on Disks the following message from Makemkv:
"This disc requires Java runtime (JRE), but none was found. Certain functions will fail, please install Java. See http://www.makemkv.com/bdjava/ for details."
I have Java RE installed but it seems, that its not recognized.
Does anybody know how to fix this?
rgds, Holger
Grauhaar
Re: BD Java - not recognized in Java RE
#2 Post by Grauhaar » Fri May 29, 2020 6:36 pm
I assume that you are using Windows.
Open a "Cmd Window" (the Terminal Window)
Type "java -version" ... what ist shown?
Good Luck :)
TheSound
#3 Post by TheSound » Fri May 29, 2020 7:39 pm
The Java Version i use is
jdk-14.0.1_windows-x64_bin
Grauhaar
#4 Post by Grauhaar » Sat May 30, 2020 2:14 am
That's not what I ask. So please ...
Provide a full Debug log and did you specify in the MakeMKV "Protection" settings anything in the "Custom Java executable location"?
Good Luck :)
FredK
#5 Post by FredK » Sat May 30, 2020 7:42 am
TheSound wrote: Fri May 29, 2020 6:03 pm Dear all,
rgds, Holger
I made the same experience. The solution for me was to install JRE8 besides JDK14.
Grauhaar
#6 Post by Grauhaar » Sat May 30, 2020 8:39 am
Yes, the OP also has a JDK (Development Kit), don't know if a JRE (Runtime Evironment) is included in this version. JDK are only needed for developers, but not for executing already build java code.
I use the Orcale JRE version from https://www.java.com/ Simply install it, no special things needs to specify in MakeMKV, it's automaticaly detected.
Good Luck :)
FredK
#7 Post by FredK » Sat May 30, 2020 12:12 pm
Grauhaar wrote: Sat May 30, 2020 8:39 am Yes, the OP also has a JDK (Development Kit), don't know if a JRE (Runtime Evironment) is included in this version.
Yes, the JDK contains the JRE. Personally, I need the full JDK because of other purposes. At last I had successfully blu-ray playback with menus after the additional installation of the actual JDK8 only. After that I stopped further investigations.
FredK
TheSound
#8 Post by TheSound » Wed Jun 03, 2020 4:43 pm
yes, right, from my side the item can be closed. i also recognized that i installed the developer kit in stead of the runtime environment. Now i put JRE on and its fine
rgds, Holger
