Libredrive version v6
Re: Libredrive version v6
Just try to rip Aquaman as an ISO on my NS60. I got about 38% or so done before the drive went nutty and threw read errors. So yes, triple layer discs at super high speed is probably not majorly awesome. But, if we can set the max read speed I bet we can get it a bit higher than "normal" and still have success. I'd love a build where we can try.
Yeah, something like a dropdown box similar to what imgburn has for the write speed would be great! As far as placement goes, maybe put it next to the eject button?SamuriHL wrote: Sun May 24, 2020 1:09 am Just try to rip Aquaman as an ISO on my NS60. I got about 38% or so done before the drive went nutty and threw read errors. So yes, triple layer discs at super high speed is probably not majorly awesome. But, if we can set the max read speed I bet we can get it a bit higher than "normal" and still have success. I'd love a build where we can try.![]()
I dunno.... just a couple of suggestions anyway....
Yea that would be fantastic. Maybe some day once we have more data about what's "safe" and what isn't LibreDrive could automagically set the max speed based on media type (double, triple, quad, super duper holy hell, etc
). But for now to get that data, having an option to select it yourself would be nice.
Downloaded link on mac says unsupported format ?
I tested a few BD and DVDs and Wow, what a difference.
Then for fun I tried a few of my UHDs that would not rip due to disc errors (even after a good cleaning). 2 of the 4 that I tried now rip.
One of the discs was Call of the Wild, so I only tried it a week ago. Before updating to LD 6 it would not rip. After LD 6, ripped with some AV sync errors (around 10:46, 10:47) but the final rip plays. The other one was ZombieLand Double Tab. I don't remember how long ago it was that I tried that rip last time.
I reported way back when LD first came out that I needed to clean UHD discs less. Looks like LD 6 has improved on that
Could you please let us know which drive and which firmware was used in your case? Thanks!
Sure. I'm using Linux.Coopervid wrote: Wed May 27, 2020 8:00 pm Could you please let us know which drive and which firmware was used in your case? Thanks!
OS device name: /dev/sr0
Product: BD-RE WH16NS40
Revision: 1.02
Serial number: SIK9LH3D8401
Firmware date: 2115-12-11 14:59
Highest AACS version: 72
Firmware version: 1.02
Unrestricted read speed: YesRe: Libredrive version v6
For folks with an NS60, which firmware do you recommend using to test this? 1.00 or MK 1.02? And are there any pros/cons to using one or the other?
1.02mk if you only use makemkv 1.00 for others no advantage or disadvantage other then 1.00 having more compatibility and 1.02mk being a single downgrade step.
How do you enable v6 in macOS? Do you have to replace some files inside the package contents of the app itself? Is there a data folder somewhere outside the app that I can drop the v6 sdf bin?jonghotti wrote: Sun May 17, 2020 6:58 pm macOS 10.15.4
BU40N slim drive unrestricted drive speed = NO
WH16NS60 = YES
edit: Never mind, I'm an idiot and answered my own question after digging into it. In case anyone else is stupid like me, check your app preferences on the General tab, 'MakeMKV data directory' will show the path you need to place the SDF file into.
/Users/~/Library/MakeMKVProduct: BD-RE WH14NS40
Revision: 1.04
TeddyRaspin
I've successfully ripped The Equalizer UHD (97 GB size disc) with both MakeMKV and IMGBurn and I have been
very impressed by the ripping speed which has reached 12x !!! (over 50 MB/s).
No issues at all using 3 different LG burners crossflashed to WH16NS60 1.02 MK firmware.
I'm trying to rip the 4K UHD version of Parasite from the disc, but when I open up MakeMKV 1.15.1, it says it cannot open the disc. Is LibreDrive the solution?
My WH16NS40 also seems to be having trouble on layer change using v6. Read speed immediately drops down to 2.0x for the rest of the session. For now I'll be sticking with v5 (at least for DL disks). Read speeds on the first layer were quite amazing though. Nearly got to 11.0x!
Edit: After some more testing, I think the disk itself was damaged and causing problems. Tried another disk and it ripped Blade Runner 2049 in under 23 minutes!
Max speed was 12.5x!!
supersonik
BH16NS55 1.04 + v6 40mb/s+ on bd50
i'm enjoying it already. thanks
TheDarkKnight
Is there any news when the Pioneer BDR-211UBK drive will be supported?
