Hello
I am having trouble ripping the new The Good Place complete set.  I’ve tried the first four disks, and for each one, at least one file fails to save.  The error message is something like 5 files saved, 2 files failed.  Or course the numbers change on different disks, but on each disk, it is always the same file(s) that won’t save.
I’ve tried different blu ray drives, i’ve changed the save to directory, i’ve cleaned the disks, i’ve increased read retry.  Nothing helped.  Before i send the disks back, what else can I try?
Running on a macbook pro.  Ausus drives
Thank you
						The Good Place Complete
Re: The Good Place Complete
Without any error messages no one can give any help. Please provide a complete debug log, maybe it helps.
									Good Luck
Hello
Here are the contents MakeMKV_log.txt
Debug log started at Sat May 23 15:43:26 2020 , written by MakeMKV v1.15.1 darwin(x64-release)
001005:0000 MakeMKV v1.15.1 darwin(x64-release) started
001004:0000 Debug logging enabled, log will be saved as /Users/jayb/MakeMKV_log.txt
002014:0000 Optical drive "BD-RE ASUS BW-16D1X-U E101" opened in DASPI v1.5 mode.
002014:0000 Optical drive "BD-RE ASUS BW-16D1HT 3.10" opened in DASPI v1.5 mode.
No  SDF v06d: ASUS_BW-16D1X-U_E101_QDDL120826WL
SDF id v06d: ASUS_BW-16D1X-U_E101_QDDL120826WL
001003:0020 DEBUG: Code 0 at _t@|m(N>uzgi%>WB4d]&-b#Dk:213131318
SDF  v06d: ASUS_BW-16D1HT_3.10_211901041014_KLIK2L84136
DEBUG: Code 0 at &{3i)-QLdg>G:Y,6c:29395540
DEBUG: Code 0 at ^W_MavfVOaQJdBrM:213141599
DEBUG: Code 0 at mRDZRJ~XOz[aS2C$:29401014
DEBUG: Code 2147483648 at ^W_MavfVOaQJdBrM:213132974
DAFD=PAAAADAAAAEABDQkEGwEBAQ==
DCE=r2aLXUYlVAr3OO2yq1DTunRM23VMYHrHvSFJEphT3C+nTXgdP0eaLuwGabP4rc37R9a1o7kRTdyxaudUtEft6rTMKp0/O8sJZ6Yz9o465SZy/iDN2GbWNBrKwbsEDi4aypwIBWpz8B8QLBZf8qumrvZ6E9Alzf3+6w==
DCE=rTpji7iQ6PBth3TCJ5beRyUF6+46rz1Ggr8duvc6EC25RBd3M29ZRSbc/kew0gfEDTajYJiQy+kZ20E9jVCs0FB9dtke+IDD73E0iT7HtLWK8TXOpL+Nv2cemyXSG4CO9ac9JTYes+9mJUxdP3CI71E1xpg1+7wYwQ==
DISCID=2FB0EFE2DBA7648D92E88C5602F942F5BC169891
003025:0000 Title #01001.mpls has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003307:0000 File 01002.mpls was added as title #0
003307:0000 File 01003.mpls was added as title #1
003307:0000 File 01004.mpls was added as title #2
003307:0000 File 01005.mpls was added as title #3
003307:0000 File 01006.mpls was added as title #4
003309:0000 Title 01007.mpls is equal to title 01002.mpls and was skipped
003307:0000 File 01007.mpls(1) was added as title #5
003307:0000 File 01008.mpls was added as title #6
003025:0000 Title #00000.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00001.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003309:0000 Title 00002.m2ts is equal to title 01002.mpls and was skipped
003309:0000 Title 00003.m2ts is equal to title 01003.mpls and was skipped
003309:0000 Title 00004.m2ts is equal to title 01004.mpls and was skipped
003309:0000 Title 00005.m2ts is equal to title 01005.mpls and was skipped
003309:0000 Title 00006.m2ts is equal to title 01006.mpls and was skipped
003309:0000 Title 00007.m2ts is equal to title 01008.mpls and was skipped
005015:0000 Saving 1 titles into directory /Users/jayb/Movies using profile 'FLAC' from file '/Applications/MakeMKV.app/Contents/MacOS/../Resources/appdata.tar:flac.mmcp.xml'
FFENC006: option compression_level=5
DEBUG: Code 256 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 512 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 768 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 1024 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 1280 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 1536 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 1792 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 2048 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 2304 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 2560 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 2816 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 3072 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 3328 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 3584 at #SxlI&%\Eds(NjVZ7?k:213132652
DEBUG: Code 3840 at #SxlI&%\Eds(NjVZ7?k:213132652
FFENC006: [flac @ 0x7f997d018e00]  compression: 5
FFENC006: [flac @ 0x7f997d018e00]  lpc type: Levinson-Durbin recursion with Welch window
FFENC006: [flac @ 0x7f997d018e00]  prediction order: 1, 8
FFENC006: [flac @ 0x7f997d018e00]  order method: estimate
FFENC006: [flac @ 0x7f997d018e00]  partition order: 0, 8
FFENC006: [flac @ 0x7f997d018e00]  block size: 4608
FFENC006: [flac @ 0x7f997d018e00]  lpc precision: 15
DEBUG: Code 4096 at #SxlI&%\Eds(NjVZ7?k:213132652
001003:0020 DEBUG: Code 0 at q{HRw("nf%C=+&M&*4^m:121263360
001003:0020 DEBUG: Code 1 at %$4P&W?OM;\l}eqJ:121264165
001003:0020 DEBUG: Code 0 at 12n3M84.-Z~c`8wRW71Q/:29400140
001003:0020 DEBUG: Code 20 at x4X}cmm2szUrCdEI:213131663
001003:0020 DEBUG: Code 0 at x4X}cmm2szUrCdEI:121265062
001003:0020 DEBUG: Code 0 at (A'N9Wk]@H?rSYv0^#IO:29393286
---- Failed /Users/jayb/Movies/The Good Place Season One- Disc One_t05.mkv
ch_0        1607295690000 0
ch_1        1608286680000 0
ch_2        1609457850000 0
ch_3        1610448840000 0
ch_4        1611259650000 0
ch_5        1612025415000 0
ch_6        1612611000000 0
ch_7        1613692080000 2
mt=0x7f997cd38560 n=5
s=0 n=4 o=38086656
    0    166 000000  1613647035000       45045000 184E5CC8 0000000209300000001006010C000A8609080FE96210000008800000001D419A001C002FE88835FFFEDAA65800000300000300000300000300015F0000001F41003FC9A001C002FE88835FFEDAA65800000300000300000300000300015F0000002041001FE268007000BFA220D7FFFEDAA65800000300000300000300000300
    0    163 000008  1613556945000       45045000 65D2B96B 0000000209500000001006010C000B0009080DE96210000008800000001C419E001E002BFB2106BF000003000003000003000003000003003D200000001F41003FC9E001E002BFB2106BFF000003000003000003000003000003003D200000001F41001FE278007800AFEC841AFF000003000003000003000003000003003D20
    0    158 000008  1613601990000       45045000 ADE4475E 0000000209500000001006010C000B8009080EE96210000008800000001B019E0020002DE41AFF000003000003000003000003000003003D200000001D01003FC9E0020002DE41AF000003000003000003000003000003003D200000001E01001FE278008000B7906BFF000003000003000003000003000003003D200000001E
    0    976 000007  1613692080000       45045000 345A1D10 0000000209100000003567640029AC1B1A501E0089F9701100000303E90000BB80E26000044AA200007270F8C4B8C4C0000895440000E4E1F18970F8E1852C0000004168EA8DCE50948D18B25A55284A468C592D2A50C91A3164B4AA8548D275D5251D2349D27A2374937A49BE95DAADD53D7A6B54229A4E93D6EA9FA4EEAAFD
s=1 n=0 o=0
s=2 n=13 o=7689781248
    2   2012 000001  1613548800000       11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108
    2   2012 000001  1613560320000       11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108
    2   2012 000001  1613571840000       11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108
    2   2012 000001  1613583360000       11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108
    2   2012 000001  1613594880000       11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108
    2   2012 000001  1613606400000       11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108
    2   2012 000001  1613617920000       11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108
    2   2012 000001  1613629440000       11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108
    2   2012 000001  1613640960000       11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108
    2   2012 000001  1613652480000       11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108
    2   2012 000001  1613664000000       11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108
    2   2012 000001  1613675520000       11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108
    2   2012 000001  1613687040000       11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108
s=3 n=1 o=39112704
    3  33099 000031  1615854240000       22522500 1F65ED7A 160013078004381000008000000100000000021C033317000A0100021C0333034800721404FD000000128080FE01108080FD024F8080FF03108080FE04688080FF05538080FF06378080FF07818080FF0810808079094C8080FF0A8C8080FF0B578080FF0C108080A60D9C8080FF0E1080805E0FB78080FF101080802C11C780
s=4 n=0 o=45084672
mt=0x7f997cd382f0 n=5
s=0 n=36 o=38086656
    0    161 000000  1613782170000       45045000 5D4D7C44 0000000209300000001006010C000084090802810210000008800000001C419A00020005906BFFFEDAA65800000300000300000300000300015F0000001E41003FC9A00020005906BFFEDAA65800000300000300000300000300015F0000001E41001FE2680008001641AFFEDAA65800000300000300000300000300015F0000
    0    163 000008  1613737125000       45045000 25F20B7D 0000000209500000001006010C000100090801810210000008800000001C019E00040003FA220D7F000003000003000003000003000003003D200000001F01003FC9E00040003FA220D7FF000003000003000003000003000003003D200000001F01001FE2780010000FE88835FF000003000003000003000003000003003D20
    0    161 000000  1613917305000       45045000 EBEC2B60 0000000209300000001006010C000186090805810210000008800000001C419A0004000B906BFFFEDAA65800000300000300000300000300015F0000001E41003FC9A0004000B906BFFEDAA65800000300000300000300000300015F0000001E41001FE2680010002E41AFFEDAA65800000300000300000300000300015F0000
    0    163 000008  1613827215000       45045000 2FEC7F34 0000000209500000001006010C000200090803810210000008800000001C419E00060007FA2106BF000003000003000003000003000003003D200000001F41003FC9E00060007FA2106BFF000003000003000003000003000003003D200000001F41001FE2780018001FE8841AFF000003000003000003000003000003003D20
    0    158 000008  1613872260000       45045000 51812F58 0000000209500000001006010C000280090804810210000008800000001B019E00080009E41AFF000003000003000003000003000003003D200000001D01003FC9E00080009E41AF000003000003000003000003000003003D200000001E01001FE27800200027906BFF000003000003000003000003000003003D200000001E
    0    166 000000  1614052440000       45045000 14B3FACE 0000000209300000001006010C000306090808810210000008800000001D419A00080011E88835FFFEDAA65800000300000300000300000300015F0000001F41003FC9A00080011E88835FFEDAA65800000300000300000300000300015F0000002041001FE26800200047A220D7FFFEDAA65800000300000300000300000300
    0    163 000008  1613962350000       45045000 3F0EA2C4 0000000209500000001006010C000380090806810210000008800000001C419E000A000DFB2106BF000003000003000003000003000003003D200000001F41003FC9E000A000DFB2106BFF000003000003000003000003000003003D200000001F41001FE27800280037EC841AFF000003000003000003000003000003003D20
    0    158 000008  1614007395000       45045000 424E61B7 0000000209500000001006010C000400090807810210000008800000001B019E000C000FE41AFF000003000003000003000003000003003D200000001D01003FC9E000C000FE41AF000003000003000003000003000003003D200000001E01001FE2780030003F906BFF000003000003000003000003000003003D200000001E
    0    166 000000  1614187575000       45045000 7C42F796 0000000209300000001006010C00048609080B810210000008800000001D419A000C0017E88835FFFEDAA65800000300000300000300000300015F0000001F41003FC9A000C0017E88835FFEDAA65800000300000300000300000300015F0000002041001FE2680030005FA220D7FFFEDAA65800000300000300000300000300
    0    163 000008  1614097485000       45045000 FBF0DFDC 0000000209500000001006010C000500090809810210000008800000001C419E000E0013FB2106BF000003000003000003000003000003003D200000001F41003FC9E000E0013FB2106BFF000003000003000003000003000003003D200000001F41001FE2780038004FEC841AFF000003000003000003000003000003003D20
    0    158 000008  1614142530000       45045000 01DEC5A4 0000000209500000001006010C00058009080A810210000008800000001B019E00100015E41AFF000003000003000003000003000003003D200000001D01003FC9E00100015E41AF000003000003000003000003000003003D200000001E01001FE27800400057906BFF000003000003000003000003000003003D200000001E
    0    166 000000  1614322710000       45045000 8FC7F429 0000000209300000001006010C00060609080E810210000008800000001D419A0010001DE88835FFFEDAA65800000300000300000300000300015F0000001F41003FC9A0010001DE88835FFEDAA65800000300000300000300000300015F0000002041001FE26800400077A220D7FFFEDAA65800000300000300000300000300
    0    163 000008  1614232620000       45045000 1315A3A6 0000000209500000001006010C00068009080C810210000008800000001C419E00120019FB2106BF000003000003000003000003000003003D200000001F41003FC9E00120019FB2106BFF000003000003000003000003000003003D200000001F41001FE27800480067EC841AFF000003000003000003000003000003003D20
    0    158 000008  1614277665000       45045000 81A7EA2C 0000000209500000001006010C00070009080D810210000008800000001B019E0014001BE41AFF000003000003000003000003000003003D200000001D01003FC9E0014001BE41AF000003000003000003000003000003003D200000001E01001FE2780050006F906BFF000003000003000003000003000003003D200000001E
    0    166 000000  1614457845000       45045000 0FE348D6 0000000209300000001006010C000786090811810210000008800000001D419A00140023E88835FFFEDAA65800000300000300000300000300015F0000001F41003FC9A00140023E88835FFEDAA65800000300000300000300000300015F0000002041001FE2680050008FA220D7FFFEDAA65800000300000300000300000300
    0    163 000008  1614367755000       45045000 8A7D19DD 0000000209500000001006010C00080009080F810210000008800000001C419E0016001FFB2106BF000003000003000003000003000003003D200000001F41003FC9E0016001FFB2106BFF000003000003000003000003000003003D200000001F41001FE2780058007FEC841AFF000003000003000003000003000003003D20
    0    158 000008  1614412800000       45045000 79F64077 0000000209500000001006010C000880090810810210000008800000001B019E00180021E41AFF000003000003000003000003000003003D200000001D01003FC9E00180021E41AF000003000003000003000003000003003D200000001E01001FE27800600087906BFF000003000003000003000003000003003D200000001E
    0    166 000000  1614592980000       45045000 C7546A6D 0000000209300000001006010C000906090814810210000008800000001D419A00180029E88835FFFEDAA65800000300000300000300000300015F0000001F41003FC9A00180029E88835FFEDAA65800000300000300000300000300015F0000002041001FE268006000A7A220D7FFFEDAA65800000300000300000300000300
    0    163 000008  1614502890000       45045000 14D800F6 0000000209500000001006010C000980090812810210000008800000001C419E001A0025FB2106BF000003000003000003000003000003003D200000001F41003FC9E001A0025FB2106BFF000003000003000003000003000003003D200000001F41001FE27800680097EC841AFF000003000003000003000003000003003D20
    0    158 000008  1614547935000       45045000 DADA47FC 0000000209500000001006010C000A00090813810210000008800000001B019E001C0027E41AFF000003000003000003000003000003003D200000001D01003FC9E001C0027E41AF000003000003000003000003000003003D200000001E01001FE2780070009F906BFF000003000003000003000003000003003D200000001E
    0    166 000000  1614728115000       45045000 626900AB 0000000209300000001006010C000A86090817810210000008800000001D419A001C002FE88835FFFEDAA65800000300000300000300000300015F0000001F41003FC9A001C002FE88835FFEDAA65800000300000300000300000300015F0000002041001FE268007000BFA220D7FFFEDAA65800000300000300000300000300
    0    163 000008  1614638025000       45045000 C73D3669 0000000209500000001006010C000B00090815810210000008800000001C419E001E002BFB2106BF000003000003000003000003000003003D200000001F41003FC9E001E002BFB2106BFF000003000003000003000003000003003D200000001F41001FE278007800AFEC841AFF000003000003000003000003000003003D20
    0    158 000008  1614683070000       45045000 167DD059 0000000209500000001006010C000B80090816810210000008800000001B019E0020002DE41AFF000003000003000003000003000003003D200000001D01003FC9E0020002DE41AF000003000003000003000003000003003D200000001E01001FE278008000B7906BFF000003000003000003000003000003003D200000001E
    0 435807 000001  1614773160000       45045000 CFD71781 0000000209100000003567640029AC1B1A501E0089F9701100000303E90000BB80E26000044AA200007270F8C4B8C4C0000895440000E4E1F18970F8E1852C0000004168EA8DCE50948D18B25A55284A468C592D2A50C91A3164B4AA8548D275D5251D2349D27A2374937A49BE95DAADD53D7A6B54229A4E93D6EA9FA4EEAAFD
    0 214387 000000  1614818205000       45045000 E72EC1F4 0000000209300000001006010C000082090801830210000008800000E6D1419A0002000391FF704CBE73DBB22B86CAF00282DB5A22D84797AABB9DF93B8469E4B85B0E6FE492490104EDF6C29B3232BE78100798FACA27C28F769B72DB8E9B353293A9CC21A2CD4C918C44AA2805CEB48871EF2DEB6BFAEE890ACD41AEE1C699
    0 185507 000000  1614908295000       45045000 3EA6F554 0000000209300000001006010C000104090803830210000008800000D05A419A0004000791FF6022A0930A639787166814D5BD152732E81A1B7C14CB1E409D261654FC562B9E96A8B7757606412178C2E230D558429607723AFC0253EB4903904F0A7A26E4FAB76B4545E18CA5C43C80E5AF2F815B93E7CF31D01B6230306CEF
    0 118330 000008  1614863250000       45045000 3BF22E6E 0000000209500000001006010C0001800908028302100000088000007577019E00060005FA223FFFEEDE5A5CFE85D58BC973759DE1A5146E76495D61CA458B83581951632D9D508FA29D3918908A9D4ED6A1AD463F699F75D935067371D8EE56D72904A49C373E94A1A497A48D1A6E2F9B8C152BD04D2985F321AB423CBBEB0B
    0 167207 000000  1614998385000       45045000 40A9B11A 0000000209300000001006010C000204090805830210000008800000BDED419A0006000B91FF5C8A0010C44CE5CDB75B068296A938D6128D7F3ACD52FE792F62FBE1949CB62801707F4F5FA31A13AA601A80C686856880ECF1C62A6B7E0FA358AC43093D2742408F1B3157A30337E78098CF6B1A683130C7AEFCF0981BF36C91
    0 122618 000008  1614953340000       45045000 767E6AB6 0000000209500000001006010C0002800908048302100000088000007E38019E00080009FA223FFFFD46995DD2DF45D4E0957AE8DEB102B18696298C0944B9BB95D7F49A28B44961C213F225A12FD17D0D750DA47D3C540BDDE9BF925BD757F358E1FC9663299598447357C605FF20A6F492D403D7C07C2D40717EEE83DFF7EE
    0 159560 000000  1615088475000       45045000 E2B25934 0000000209300000001006010C000304090807830210000008800000B7E0419A0008000F91FF5CE5CBA44820873369597C07AC73B39294AD903738C0650800524B48320D43DC54013639C2C8B656FCF66C94001F4657EBB5073373795C4961B4130E972B2727AD0383D11B2C0D69673D3A9AB757A3328DC6FD2B29351A00EA56
    0 109900 000008  1615043430000       45045000 65C10E02 0000000209500000001006010C0003800908068302100000088000007406019E000A000DFA2237FFFDB21CDFC011BAAD559E6954669C67110BCB4597AF6D9A7459A3C509FA77B40ED2E2B0DD7867EC63BF8EFC5EC9CF86792C04C3186D284E538E086AFE734B91252ADA87593C7091715D7D93E98BEBC60C11D6E6375DE13F56
    0 160954 000000  1615178565000       45045000 793F6B3B 0000000209300000001006010C000404090809830210000008800000B6DF419A000A001391BF57F0C86EDFA6E4776EDD5A762D979FDDBC3AD62066F03EBCFF4405A6ECD15AB086C2A01E887199811B95D2508C2B8039066FDA941283C4EECC70B01447DD0E86A7F89950386E13D773AA0643BC124E315D986ED47C9FA8978D18
    0 108476 000008  1615133520000       45045000 AE21C532 0000000209500000001006010C000480090808830210000008800000727D019E000C0011FA2237FFF8FCEF827092E86A081E4EED73853CDD7B5DB8B6F1F44C0EC0F50A581DA6D098779D3CCB0ABDB9CD48E7E0520A89FE227BECCA5E95497B4735011963FD4546EF3D58508C64C259913FB431CAA6636D8E1B524FB6C2064F10
    0 237285 000000  1615268655000       45045000 33D2CC49 0000000209300000001006010C00050409080B83021000000880000100F3419A000C0017908F65D701EF59C668674BA48A781DA32C1D1E045E66E98F00C7EE818BD449053BC23E280D97E6462372DE3CAFE57EA1F023AC65E26196A3BCC637C4170F753ACE026F669AFFC5A364DC36E75148042C1C8F812AD7E7474EB3E90F31
    0 180761 000008  1615223610000       45045000 8E8E90B5 0000000209500000001006010C00058009080A830210000008800000BC82019E000E0015FA2211FFFD4BBF6F83A4E167E931976FA9E16A9C41AFA619335CDB4A87A891EC522BC292B08C5083DAA595190E11E1F4936F516922D7AC6FDFC7061F4A0601A1233C09C499BC90C971C3F7885E3E5AD4453C19E5FA6E76F5502E2093
    0 147683 000000  1615358745000       45045000 18A1E86F 0000000209300000001006010C00060409080D830210000008800000AA75419A000E001B91BF5526370EEC2FC5E8CDCFDF11F8A252B7388C11A5CF232D2D4CF8CED48910947F9A2EA0FAF31929EA4BFE28224ED94D5C9248ACBF43F75A2B7E8F3279076A8EC54E29F1C5FDEB4BB5C7AE67D3427B317C01C883EEF782D41454BB
s=1 n=7 o=0
    1     34 000000  1613571840000             -1 344AE1C9 FFF85A5CE3B38BBC000000000000000000000000000000000000000000000000E8E8
    1     34 000000  1613675520000             -1 043A90D3 FFF85A5CE3B38CA9000000000000000000000000000000000000000000000000B604
    1     34 000000  1613779200000             -1 27909B62 FFF85A5CE3B38DAE000000000000000000000000000000000000000000000000A990
    1     34 000000  1613882880000             -1 F57346B5 FFF85A5CE3B38EA7000000000000000000000000000000000000000000000000892C
    1     34 000000  1613986560000             -1 D6D94D04 FFF85A5CE3B38FA000000000000000000000000000000000000000000000000096B8
    1     34 000000  1614090240000             -1 B0E5C42E FFF85A5CE3B390FD0000000000000000000000000000000000000000000000004DB1
    1     34 000000  1614193920000             -1 934FCF9F FFF85A5CE3B391FA0000000000000000000000000000000000000000000000005225
s=2 n=0 o=7689781248
s=3 n=0 o=39112704
s=4 n=0 o=45084672
mt=0x7f997ce165c0 n=5
s=0 n=24 o=38086656
    0 151869 000008  1615313700000       45045000 753518FC 0000000209500000001006010C00068009080C8302100000088000009E09019E00100019FA223FFFFD444AA88A24C01BE2A05E04A3002CBABE8E0BB669F8EB060306B5F1954FC3837C8128518577E1149D5C245013B39C9CAF98FA81393A368E9C92C04B4680D9B45B77DED5A3BF2943B6E83004F080B23DA89F0BC8BFF8EE80
    0 206036 000000  1615448835000       45045000 3D969AE3 0000000209300000001006010C00070409080F830210000008800000E61A419A0010001F91FF614DEE8E2C67AB3BB00FA8072BED0A661970A13F7D1EC60531A5039E7A86B6D66BA05A9EAD237ACD45E91C10C797459F577869599D0150BF0B18F584B6BD02F119FC48708E2C563424FEF342C39C5BB604900B9D7F9C38A1BDB8
    0 147946 000008  1615403790000       45045000 46DAB479 0000000209500000001006010C00078009080E8302100000088000009BDA019E0012001DFA223FFFFD55EAF6646806C34D3F49096CA00E716FA0B2EE9099263C845861591ED70E6BBF2F48EFBAE9AAA49382BF9BB56E0604B093677B4652ABE2846A13A8B7EA1F04D4E82B132F7BCE585AE8942CCB8EFE01A8E340828EFFE9AC
    0 213997 000000  1615538925000       45045000 FAC5CE17 0000000209300000001006010C000804090811830210000008800000EEC8419A0012002391FF5CD24B869BDC9468489C9986AE592B25BF2B39A99FAE04EA2363A45AF26A7ED0C97829EFFE68F430587A6C47F1047B0698A4696315771E52E5451683BAC86C9C8430748CD7D936E27CA7399D08B63DCEC5C1E7B207FD48D54007
    0 154300 000008  1615493880000       45045000 A4328C00 0000000209500000001006010C000880090810830210000008800000A573019E00140021FA223FFFEEDE833213B400BE6AA5D8382FF88AB89BCFA8297659CAC57C868AD1D8CD86EEFBDF945EB6E4F0A48DA42BE032752085E49C4CEEC1DFA9FA049F885B8CE1A060714401DB7A176CD29F2E1CFFAB944A8EDA3F728F2F55A6D7
    0 215502 000000  1615629015000       45045000 59373F78 0000000209300000001006010C000904090813830210000008800000F0A3419A00140027908F62B3EA3A882FC6D1816DAC602CCD86C721EC0571AC9FA8D27549289840D59E406B7AABCCB3CD51CF02B245EBF7AF8D65E9DA983A051E1F81A69FAEA7235201B05A85A1DB7E4C4425B9DF427589688E40FE5D14687068D168EF72
    0 139678 000008  1615583970000       45045000 028F5C5A 0000000209500000001006010C000980090812830210000008800000934F019E00160025FA223FFFEEDD86B14560728D112BBB973788EA3EBDB44759EF9AB51F52EA331858CD608B5E7CC8F4E971A6A6DA99230B9BD35255F93F06189D9D47FF39B6BE32AC47991BB9FD861699D5FABC4156B23B0B45F2252984F814E926A9C8
    0 204924 000000  1615719105000       45045000 E48C38CB 0000000209300000001006010C000A04090815830210000008800000E82B419A0016002B908F69064FD8DEA68C1F7377254413309127E538DF31593574D5B41318A3AA383BA1AB399A0D5E6B861393886767EC4076C2713FFDC775F321919D6338C7C3E871CF5B8FA35A18B3394339A871CAF03B5720B013CE04D4C4E6D149DA
    0 156467 000008  1615674060000       45045000 462680F3 0000000209500000001006010C000A80090814830210000008800000A692019E00180029FA2211FFFD384517CE210306C5AE9D0FD96AF8FD9329A61C7E28A9C96D1DD835B914978E5314604B85DD71E052A8FE77040ABF898B133193ACFE8D65C09A9469D57E28A4F92BC0EBBDC80502BB3F54D1E8D70048B129734D4FF7FA42
    0 214741 000000  1615809195000       45045000 6D48D4F0 0000000209300000001006010C000B04090817830210000008800000F52A419A0018002F908F5D15E250D3947E261C2C69BB2617FEEC3DDC8D8EBC6638C9BAA9CEECA9885EDA60352A66CCAFE3C6ECDBD3D916F0B5D6D70BB7376F3B17F4DFDFFC090910C27D57F5517910231251BAD558C3157589BDCFBBA2A26A127E055A94
    0 144328 000008  1615764150000       45045000 5DE50F39 0000000209500000001006010C000B800908168302100000088000009C61019E001A002DFA2211FFF0794E151E5347E8621FA559BE804D4EEF7F77C18D568F93983246F624B1C05AD28C263D6F40CF85FC77EEBACEC531B6BFD1799DF05CAAC03E665B3706D7480531388864041E67068D86E78BA759CE3D13546777009558A7
    0 437145 000001  1615944330000       45045000 C6831430 0000000209100000003567640029AC1B1A501E0089F9701100000303E90000BB80E26000044AA200007270F8C4B8C4C0000895440000E4E1F18970F8E1852C0000004168EA8DCE50948D18B25A55284A468C592D2A50C91A3164B4AA8548D275D5251D2349D27A2374937A49BE95DAADD53D7A6B54229A4E93D6EA9FA4EEAAFD
    0 124579 000008  1615854240000       45045000 5DFFC571 0000000209500000001006010C0000800908008502100000088000008BCC419E001C0031FA211FFFFD52657501729A3C72C33604B1D9B09C8B011E4164345E607BA1F076F422EB3B0AA19752F2B719B2A3608C7B483EAD18E86BC15BF507F31917B69D8C373A6067E470A94D54687888322443E2689EBC5A6FF8BEDC81AC9BEC
    0 106692 000008  1615899285000       45045000 05D3005C 0000000209500000001006010C0001000908018502100000088000007324019E001E0033E47FEF396BB79F729CA934BCDEABBA851FB8945218426D18087B6F84488AB22F37E084EE6A3EE1045164B68DB783244246BACDB021FC3D0EB5FBC365D14685127DF6032247985BF16B3F0352BD9C1255C9C3913725D7F848FB627D29
    0 218660 000000  1616034420000       45045000 A013CA79 0000000209300000001006010C000184090804850210000008800000EC20419A001E0039E888FF6037E364238CB9B96B9B52C19709725CB3E0097B98176B04E983C9E0BBFC30B79E845C97C80A1F84A046C278C3E49A2D872EDC6FEAE90D7FBD7DD774B2702ED8065BCEE8C885FACFFA1DA0F42A2E8ED4D92A6230627C941BE8
    0 227894 000008  1615989375000       45045000 FA62BBB7 0000000209500000001006010C000200090803850210000008800000EF6B019E00200037FB2213FFF15C3278E8704A35E2779844E62228BC3D52A5AB84CA630372DF8F8AC078700E56FFD993C503B896ED52D8C6A3B8C2DA7DE74D8455CDF6C4C7C583888D02F4E2CD0D1AD7A037746C188564B12B7E8BF3911B221FD542EA9F
    0 201760 000000  1616124510000       45045000 04719C74 0000000209300000001006010C000284090806850210000008800000DB96419A0020003D91FF538A6CE0DD76F7F9F0018D46ABD3DE2D71142A9E9C16E9F485B7C7C12362B16F6E2A6AF9838F6D07FFF90AAB2D7B373F41E9B9521D8751B6C2120128F15ACD0AACF0434E0BDA72076A3FC6463BFDA4C5530EC56A1241B688D9EE
    0 177707 000008  1616079465000       45045000 DE49F9D8 0000000209500000001006010C000300090805850210000008800000B7B1019E0022003BFA2211FFF04E7BA4D1494C4F48F5F832ACD852A6EF0E77427CFDFAE4259C05232A0543779DA98D9771ED1D48DCCA290406906072E179CFB50F3816C47F81705A5BD1C09676FF44488629472DBB45399328F35398DD7C1BBDEB4903FC
    0 174891 000000  1616259645000       45045000 6F578298 0000000209300000001006010C000386090809850210000008800000BE3B419A0022004391FF5E54F6B7B90DA5406332266711756308062CBA0B580371502C9CA5315AB5E3D4454D9DC18F79C360DB4BC3F4535A9D86799EAEE82DD05E99873179EB873E2B6C540908BFF70611CA3E4C379F0E3C342827E34471E608703CAE63
    0 114271 000008  1616169555000       45045000 B8D5D36A 0000000209500000001006010C00040009080785021000000880000077E1419E0024003FFA211FFFFD529C81EB0E405FC114EE4E54E03ACA834C7693C8FBF08E4179F5BB2BD19C34AE7A425DEC69D8B3CB5B1520995D5B741C67E220ABCFB7A1A99DB58F9F0DE18ED71B5C3789E28C2F1F09BCE9D27F201F56ABCA6FD9BA0F3F
    0 130859 000008  1616214600000       45045000 EC224BC2 0000000209500000001006010C00048009080885021000000880000084CD019E00260041E47FF8CD5C136BE3074C57DF6E87C3CBD1B7DAC4F6D875ED495BA6F62E6EDE92B60597E4FDAA0070412AE2AD2E042471AE8B18ED52922831C2ABE26DBD83E2AB10AB2064BDB29851F7C407D53D41D44D06A34AF36F7F4BCD02C63518
    0 244992 000000  1616394780000       45045000 EC2A2280 0000000209300000001006010C00050609080C850210000008800000FDE4419A00260049E88847FF6712DEABDAA13AB7C057739BB9640AA2F2009468FE0214A25FEE1BFC94B3C43AB87B8CAA8DCA2C59EDCDCB0F5FC537F9CD850CEF5AD292337AC2C8EFAD1EB8F205B1B97BBF8FEB9CB1F7A4C1ACA5BBA840E24A0E5F69E319
    0 163743 000008  1616304690000       45045000 2E32B1FC 0000000209500000001006010C00058009080A850210000008800000B325419E00280045FB2108FFF04E29351D159433855799F6B76E95CEB8BE4499B9CFCF50149D02B08F8A04CEB42A84D5242EAB61D49506FBA6B469F95FA7599408E027DE024DFE7CCD5B13FB43262E73982E35BA1E5B4C9575A9130B10242B094214FF57
    0 103644 000008  1616349735000       45045000 390093B2 0000000209500000001006010C00060009080B8502100000088000006CD7019E002A0047E47FEEDE8441FC4A9C060042FC913CD6268C2CDD82340CDD840544A0F7F2F74B6E357A998D21B008EBEACF04911D7110910D3AB970BADC63C9EA843F424CC71E9D3BAF89E1930A6D25093F1D16A4EB52BFA9A1204796B5E1F028C0D3
s=1 n=3 o=0
    1   9216 000001  1614620160000       11520000 2CE07977 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
    1   9216 000001  1613692080000       11520000 2CE07977 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
    1   9216 000001  1613703600000       11520000 2CE07977 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
s=2 n=1 o=7689781248
    2   2012 006001  1613698560000       11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108
s=3 n=0 o=39112704
s=4 n=0 o=45084672
005003:0000 Failed to save title 5 to file /Users/jayb/Movies/The Good Place Season One- Disc One_t05.mkv
005004:0080 0 titles saved, 1 failed
A lot of Debug Codes ...
Can you change used profile from "Flac" to "Default" to make sure that this is not a conversion problem.
Good Luck
I am having similar issues with 1.15.1 on latest OX as well. Same thing, makemkv fails in the exact same way in midflight (about 40 minutes in) with no real error code other than Error while reading input. I assume an I/O error on a read(3)? No idea.
Here is my debug log:
viewtopic.php?f=8&t=22293
jayb3369 wrote: ↑Sat May 23, 2020 3:53 pmHello
Debug log started at Sat May 23 15:43:26 2020 , written by MakeMKV v1.15.1 darwin(x64-release) Using 262272KB for read cache. 001005:0000 MakeMKV v1.15.1 darwin(x64-release) started 001004:0000 Debug logging enabled, log will be saved as /Users/jayb/MakeMKV_log.txt 002014:0000 Optical drive "BD-RE ASUS BW-16D1X-U E101" opened in DASPI v1.5 mode. 002014:0000 Optical drive "BD-RE ASUS BW-16D1HT 3.10" opened in DASPI v1.5 mode. No SDF v06d: ASUS_BW-16D1X-U_E101_QDDL120826WL SDF id v06d: ASUS_BW-16D1X-U_E101_QDDL120826WL 001003:0020 DEBUG: Code 0 at _t@|m(N>uzgi%>WB4d]&-b#Dk:213131318 SDF v06d: ASUS_BW-16D1HT_3.10_211901041014_KLIK2L84136 003007:0000 Using direct disc access mode No SDF v06d: ASUS_BW-16D1X-U_E101_QDDL120826WL DEBUG: Code 0 at &{3i)-QLdg>G:Y,6c:29395540 DEBUG: Code 0 at ^W_MavfVOaQJdBrM:213141599 DEBUG: Code 0 at mRDZRJ~XOz[aS2C$:29401014 005085:0000 Loaded content hash table, will verify integrity of M2TS files. DEBUG: Code 2147483648 at ^W_MavfVOaQJdBrM:213132974 DAFD=PAAAADAAAAEABDQkEGwEBAQ== DCE=r2aLXUYlVAr3OO2yq1DTunRM23VMYHrHvSFJEphT3C+nTXgdP0eaLuwGabP4rc37R9a1o7kRTdyxaudUtEft6rTMKp0/O8sJZ6Yz9o465SZy/iDN2GbWNBrKwbsEDi4aypwIBWpz8B8QLBZf8qumrvZ6E9Alzf3+6w== DCE=rTpji7iQ6PBth3TCJ5beRyUF6+46rz1Ggr8duvc6EC25RBd3M29ZRSbc/kew0gfEDTajYJiQy+kZ20E9jVCs0FB9dtke+IDD73E0iT7HtLWK8TXOpL+Nv2cemyXSG4CO9ac9JTYes+9mJUxdP3CI71E1xpg1+7wYwQ== DISCID=2FB0EFE2DBA7648D92E88C5602F942F5BC169891 003025:0000 Title #01001.mpls has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped 003307:0000 File 01002.mpls was added as title #0 003307:0000 File 01003.mpls was added as title #1 003307:0000 File 01004.mpls was added as title #2 003307:0000 File 01005.mpls was added as title #3 003307:0000 File 01006.mpls was added as title #4 003309:0000 Title 01007.mpls is equal to title 01002.mpls and was skipped 003307:0000 File 01007.mpls(1) was added as title #5 003307:0000 File 01008.mpls was added as title #6 003025:0000 Title #00000.m2ts has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped 003025:0000 Title #00001.m2ts has length of 53 seconds which is less than minimum title length of 120 seconds and was therefore skipped 003309:0000 Title 00002.m2ts is equal to title 01002.mpls and was skipped 003309:0000 Title 00003.m2ts is equal to title 01003.mpls and was skipped 003309:0000 Title 00004.m2ts is equal to title 01004.mpls and was skipped 003309:0000 Title 00005.m2ts is equal to title 01005.mpls and was skipped 003309:0000 Title 00006.m2ts is equal to title 01006.mpls and was skipped 003309:0000 Title 00007.m2ts is equal to title 01008.mpls and was skipped 005011:0000 Operation successfully completed 005015:0000 Saving 1 titles into directory /Users/jayb/Movies using profile 'FLAC' from file '/Applications/MakeMKV.app/Contents/MacOS/../Resources/appdata.tar:flac.mmcp.xml' FFENC006: option compression_level=5 DEBUG: Code 256 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 512 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 768 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 1024 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 1280 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 1536 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 1792 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 2048 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 2304 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 2560 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 2816 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 3072 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 3328 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 256 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 512 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 768 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 1024 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 1280 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 1536 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 1792 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 2048 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 2304 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 2560 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 2816 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 3072 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 3328 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 3584 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 3840 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 256 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 512 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 768 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 1024 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 1280 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 1536 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 1792 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 2048 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 2304 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 2560 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 2816 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 3072 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 256 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 512 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 768 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 1024 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 1280 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 1536 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 1792 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 2048 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 2304 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 2560 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 2816 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 3072 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 3328 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 3584 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 3584 at #SxlI&%\Eds(NjVZ7?k:213132652 DEBUG: Code 3840 at #SxlI&%\Eds(NjVZ7?k:213132652 FFENC006: [flac @ 0x7f997d018e00] compression: 5 FFENC006: [flac @ 0x7f997d018e00] lpc type: Levinson-Durbin recursion with Welch window FFENC006: [flac @ 0x7f997d018e00] prediction order: 1, 8 FFENC006: [flac @ 0x7f997d018e00] order method: estimate FFENC006: [flac @ 0x7f997d018e00] partition order: 0, 8 FFENC006: [flac @ 0x7f997d018e00] block size: 4608 FFENC006: [flac @ 0x7f997d018e00] lpc precision: 15 DEBUG: Code 4096 at #SxlI&%\Eds(NjVZ7?k:213132652 001003:0020 DEBUG: Code 0 at q{HRw("nf%C=+&M&*4^m:121263360 001003:0020 DEBUG: Code 1 at %$4P&W?OM;\l}eqJ:121264165 001003:0020 DEBUG: Code 0 at 12n3M84.-Z~c`8wRW71Q/:29400140 001003:0020 DEBUG: Code 20 at x4X}cmm2szUrCdEI:213131663 001003:0020 DEBUG: Code 0 at x4X}cmm2szUrCdEI:121265062 001003:0020 DEBUG: Code 0 at (A'N9Wk]@H?rSYv0^#IO:29393286 001003:0020 DEBUG: Code 0 at 12n3M84.-Z~c`8wRW71Q/:29400140 001002:0020 LIBMKV_TRACE: Exception: Error while reading input ---- Failed /Users/jayb/Movies/The Good Place Season One- Disc One_t05.mkv ch_0 1607295690000 0 ch_1 1608286680000 0 ch_2 1609457850000 0 ch_3 1610448840000 0 ch_4 1611259650000 0 ch_5 1612025415000 0 ch_6 1612611000000 0 ch_7 1613692080000 2 mt=0x7f997cd38560 n=5 s=0 n=4 o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s=1 n=0 o=0 s=2 n=13 o=7689781248 2 2012 000001 1613548800000 11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108 2 2012 000001 1613560320000 11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108 2 2012 000001 1613571840000 11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108 2 2012 000001 1613583360000 11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108 2 2012 000001 1613594880000 11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108 2 2012 000001 1613606400000 11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108 2 2012 000001 1613617920000 11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108 2 2012 000001 1613629440000 11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108 2 2012 000001 1613640960000 11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108 2 2012 000001 1613652480000 11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108 2 2012 000001 1613664000000 11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108 2 2012 000001 1613675520000 11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108 2 2012 000001 1613687040000 11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108 s=3 n=1 o=39112704 3 33099 000031 1615854240000 22522500 1F65ED7A 160013078004381000008000000100000000021C033317000A0100021C0333034800721404FD000000128080FE01108080FD024F8080FF03108080FE04688080FF05538080FF06378080FF07818080FF0810808079094C8080FF0A8C8080FF0B578080FF0C108080A60D9C8080FF0E1080805E0FB78080FF101080802C11C780 s=4 n=0 o=45084672 mt=0x7f997cd382f0 n=5 s=0 n=36 o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s=1 n=7 o=0 1 34 000000 1613571840000 -1 344AE1C9 FFF85A5CE3B38BBC000000000000000000000000000000000000000000000000E8E8 1 34 000000 1613675520000 -1 043A90D3 FFF85A5CE3B38CA9000000000000000000000000000000000000000000000000B604 1 34 000000 1613779200000 -1 27909B62 FFF85A5CE3B38DAE000000000000000000000000000000000000000000000000A990 1 34 000000 1613882880000 -1 F57346B5 FFF85A5CE3B38EA7000000000000000000000000000000000000000000000000892C 1 34 000000 1613986560000 -1 D6D94D04 FFF85A5CE3B38FA000000000000000000000000000000000000000000000000096B8 1 34 000000 1614090240000 -1 B0E5C42E FFF85A5CE3B390FD0000000000000000000000000000000000000000000000004DB1 1 34 000000 1614193920000 -1 934FCF9F FFF85A5CE3B391FA0000000000000000000000000000000000000000000000005225 s=2 n=0 o=7689781248 s=3 n=0 o=39112704 s=4 n=0 o=45084672 mt=0x7f997ce165c0 n=5 s=0 n=24 o=38086656 0 151869 000008 1615313700000 45045000 753518FC 0000000209500000001006010C00068009080C8302100000088000009E09019E00100019FA223FFFFD444AA88A24C01BE2A05E04A3002CBABE8E0BB669F8EB060306B5F1954FC3837C8128518577E1149D5C245013B39C9CAF98FA81393A368E9C92C04B4680D9B45B77DED5A3BF2943B6E83004F080B23DA89F0BC8BFF8EE80 0 206036 000000 1615448835000 45045000 3D969AE3 0000000209300000001006010C00070409080F830210000008800000E61A419A0010001F91FF614DEE8E2C67AB3BB00FA8072BED0A661970A13F7D1EC60531A5039E7A86B6D66BA05A9EAD237ACD45E91C10C797459F577869599D0150BF0B18F584B6BD02F119FC48708E2C563424FEF342C39C5BB604900B9D7F9C38A1BDB8 0 147946 000008 1615403790000 45045000 46DAB479 0000000209500000001006010C00078009080E8302100000088000009BDA019E0012001DFA223FFFFD55EAF6646806C34D3F49096CA00E716FA0B2EE9099263C845861591ED70E6BBF2F48EFBAE9AAA49382BF9BB56E0604B093677B4652ABE2846A13A8B7EA1F04D4E82B132F7BCE585AE8942CCB8EFE01A8E340828EFFE9AC 0 213997 000000 1615538925000 45045000 FAC5CE17 0000000209300000001006010C000804090811830210000008800000EEC8419A0012002391FF5CD24B869BDC9468489C9986AE592B25BF2B39A99FAE04EA2363A45AF26A7ED0C97829EFFE68F430587A6C47F1047B0698A4696315771E52E5451683BAC86C9C8430748CD7D936E27CA7399D08B63DCEC5C1E7B207FD48D54007 0 154300 000008 1615493880000 45045000 A4328C00 0000000209500000001006010C000880090810830210000008800000A573019E00140021FA223FFFEEDE833213B400BE6AA5D8382FF88AB89BCFA8297659CAC57C868AD1D8CD86EEFBDF945EB6E4F0A48DA42BE032752085E49C4CEEC1DFA9FA049F885B8CE1A060714401DB7A176CD29F2E1CFFAB944A8EDA3F728F2F55A6D7 0 215502 000000 1615629015000 45045000 59373F78 0000000209300000001006010C000904090813830210000008800000F0A3419A00140027908F62B3EA3A882FC6D1816DAC602CCD86C721EC0571AC9FA8D27549289840D59E406B7AABCCB3CD51CF02B245EBF7AF8D65E9DA983A051E1F81A69FAEA7235201B05A85A1DB7E4C4425B9DF427589688E40FE5D14687068D168EF72 0 139678 000008 1615583970000 45045000 028F5C5A 0000000209500000001006010C000980090812830210000008800000934F019E00160025FA223FFFEEDD86B14560728D112BBB973788EA3EBDB44759EF9AB51F52EA331858CD608B5E7CC8F4E971A6A6DA99230B9BD35255F93F06189D9D47FF39B6BE32AC47991BB9FD861699D5FABC4156B23B0B45F2252984F814E926A9C8 0 204924 000000 1615719105000 45045000 E48C38CB 0000000209300000001006010C000A04090815830210000008800000E82B419A0016002B908F69064FD8DEA68C1F7377254413309127E538DF31593574D5B41318A3AA383BA1AB399A0D5E6B861393886767EC4076C2713FFDC775F321919D6338C7C3E871CF5B8FA35A18B3394339A871CAF03B5720B013CE04D4C4E6D149DA 0 156467 000008 1615674060000 45045000 462680F3 0000000209500000001006010C000A80090814830210000008800000A692019E00180029FA2211FFFD384517CE210306C5AE9D0FD96AF8FD9329A61C7E28A9C96D1DD835B914978E5314604B85DD71E052A8FE77040ABF898B133193ACFE8D65C09A9469D57E28A4F92BC0EBBDC80502BB3F54D1E8D70048B129734D4FF7FA42 0 214741 000000 1615809195000 45045000 6D48D4F0 0000000209300000001006010C000B04090817830210000008800000F52A419A0018002F908F5D15E250D3947E261C2C69BB2617FEEC3DDC8D8EBC6638C9BAA9CEECA9885EDA60352A66CCAFE3C6ECDBD3D916F0B5D6D70BB7376F3B17F4DFDFFC090910C27D57F5517910231251BAD558C3157589BDCFBBA2A26A127E055A94 0 144328 000008 1615764150000 45045000 5DE50F39 0000000209500000001006010C000B800908168302100000088000009C61019E001A002DFA2211FFF0794E151E5347E8621FA559BE804D4EEF7F77C18D568F93983246F624B1C05AD28C263D6F40CF85FC77EEBACEC531B6BFD1799DF05CAAC03E665B3706D7480531388864041E67068D86E78BA759CE3D13546777009558A7 0 437145 000001 1615944330000 45045000 C6831430 0000000209100000003567640029AC1B1A501E0089F9701100000303E90000BB80E26000044AA200007270F8C4B8C4C0000895440000E4E1F18970F8E1852C0000004168EA8DCE50948D18B25A55284A468C592D2A50C91A3164B4AA8548D275D5251D2349D27A2374937A49BE95DAADD53D7A6B54229A4E93D6EA9FA4EEAAFD 0 124579 000008 1615854240000 45045000 5DFFC571 0000000209500000001006010C0000800908008502100000088000008BCC419E001C0031FA211FFFFD52657501729A3C72C33604B1D9B09C8B011E4164345E607BA1F076F422EB3B0AA19752F2B719B2A3608C7B483EAD18E86BC15BF507F31917B69D8C373A6067E470A94D54687888322443E2689EBC5A6FF8BEDC81AC9BEC 0 106692 000008 1615899285000 45045000 05D3005C 0000000209500000001006010C0001000908018502100000088000007324019E001E0033E47FEF396BB79F729CA934BCDEABBA851FB8945218426D18087B6F84488AB22F37E084EE6A3EE1045164B68DB783244246BACDB021FC3D0EB5FBC365D14685127DF6032247985BF16B3F0352BD9C1255C9C3913725D7F848FB627D29 0 218660 000000 1616034420000 45045000 A013CA79 0000000209300000001006010C000184090804850210000008800000EC20419A001E0039E888FF6037E364238CB9B96B9B52C19709725CB3E0097B98176B04E983C9E0BBFC30B79E845C97C80A1F84A046C278C3E49A2D872EDC6FEAE90D7FBD7DD774B2702ED8065BCEE8C885FACFFA1DA0F42A2E8ED4D92A6230627C941BE8 0 227894 000008 1615989375000 45045000 FA62BBB7 0000000209500000001006010C000200090803850210000008800000EF6B019E00200037FB2213FFF15C3278E8704A35E2779844E62228BC3D52A5AB84CA630372DF8F8AC078700E56FFD993C503B896ED52D8C6A3B8C2DA7DE74D8455CDF6C4C7C583888D02F4E2CD0D1AD7A037746C188564B12B7E8BF3911B221FD542EA9F 0 201760 000000 1616124510000 45045000 04719C74 0000000209300000001006010C000284090806850210000008800000DB96419A0020003D91FF538A6CE0DD76F7F9F0018D46ABD3DE2D71142A9E9C16E9F485B7C7C12362B16F6E2A6AF9838F6D07FFF90AAB2D7B373F41E9B9521D8751B6C2120128F15ACD0AACF0434E0BDA72076A3FC6463BFDA4C5530EC56A1241B688D9EE 0 177707 000008 1616079465000 45045000 DE49F9D8 0000000209500000001006010C000300090805850210000008800000B7B1019E0022003BFA2211FFF04E7BA4D1494C4F48F5F832ACD852A6EF0E77427CFDFAE4259C05232A0543779DA98D9771ED1D48DCCA290406906072E179CFB50F3816C47F81705A5BD1C09676FF44488629472DBB45399328F35398DD7C1BBDEB4903FC 0 174891 000000 1616259645000 45045000 6F578298 0000000209300000001006010C000386090809850210000008800000BE3B419A0022004391FF5E54F6B7B90DA5406332266711756308062CBA0B580371502C9CA5315AB5E3D4454D9DC18F79C360DB4BC3F4535A9D86799EAEE82DD05E99873179EB873E2B6C540908BFF70611CA3E4C379F0E3C342827E34471E608703CAE63 0 114271 000008 1616169555000 45045000 B8D5D36A 0000000209500000001006010C00040009080785021000000880000077E1419E0024003FFA211FFFFD529C81EB0E405FC114EE4E54E03ACA834C7693C8FBF08E4179F5BB2BD19C34AE7A425DEC69D8B3CB5B1520995D5B741C67E220ABCFB7A1A99DB58F9F0DE18ED71B5C3789E28C2F1F09BCE9D27F201F56ABCA6FD9BA0F3F 0 130859 000008 1616214600000 45045000 EC224BC2 0000000209500000001006010C00048009080885021000000880000084CD019E00260041E47FF8CD5C136BE3074C57DF6E87C3CBD1B7DAC4F6D875ED495BA6F62E6EDE92B60597E4FDAA0070412AE2AD2E042471AE8B18ED52922831C2ABE26DBD83E2AB10AB2064BDB29851F7C407D53D41D44D06A34AF36F7F4BCD02C63518 0 244992 000000 1616394780000 45045000 EC2A2280 0000000209300000001006010C00050609080C850210000008800000FDE4419A00260049E88847FF6712DEABDAA13AB7C057739BB9640AA2F2009468FE0214A25FEE1BFC94B3C43AB87B8CAA8DCA2C59EDCDCB0F5FC537F9CD850CEF5AD292337AC2C8EFAD1EB8F205B1B97BBF8FEB9CB1F7A4C1ACA5BBA840E24A0E5F69E319 0 163743 000008 1616304690000 45045000 2E32B1FC 0000000209500000001006010C00058009080A850210000008800000B325419E00280045FB2108FFF04E29351D159433855799F6B76E95CEB8BE4499B9CFCF50149D02B08F8A04CEB42A84D5242EAB61D49506FBA6B469F95FA7599408E027DE024DFE7CCD5B13FB43262E73982E35BA1E5B4C9575A9130B10242B094214FF57 0 103644 000008 1616349735000 45045000 390093B2 0000000209500000001006010C00060009080B8502100000088000006CD7019E002A0047E47FEEDE8441FC4A9C060042FC913CD6268C2CDD82340CDD840544A0F7F2F74B6E357A998D21B008EBEACF04911D7110910D3AB970BADC63C9EA843F424CC71E9D3BAF89E1930A6D25093F1D16A4EB52BFA9A1204796B5E1F028C0D3 s=1 n=3 o=0 1 9216 000001 1614620160000 11520000 2CE07977 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 1 9216 000001 1613692080000 11520000 2CE07977 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 1 9216 000001 1613703600000 11520000 2CE07977 0000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000 s=2 n=1 o=7689781248 2 2012 006001 1613698560000 11520000 D423D7F8 7FFE8001FC3C7DB277000D3B8009EF7BDEDEF7BD8000FFF6DB6DB6FFFFFFFFFFFFFFFFFFFFFFFFFFFFFF400000000000000000000000000000000000000006318C6318C6318C6318C6318C6318C6318C20C518821084210842108421084210842109CC518821084210842108421084210842109CC51882108421084210842108 s=3 n=0 o=39112704 s=4 n=0 o=45084672 005003:0000 Failed to save title 5 to file /Users/jayb/Movies/The Good Place Season One- Disc One_t05.mkv 005004:0080 0 titles saved, 1 failed 005037:0204 Copy complete. 0 titles saved, 1 failed.
HEY, do you have more than audio track (like 5.1 vs stereo)? If so, try to use MakeMKV by deselect one of the audio tracks - that worked for me (in my case it was the stereo one that was giving me grief).
Re: The Good Place Complete
It changed the profile from FLAC to default and that worked.  I saw some av sync errors in the error log, so i suspect that was the problem
