Dolby Vision and 1.15.1
steffenmanden
Re: Dolby Vision and 1.15.1
Post by steffenmanden » Mon May 25, 2020 6:03 am
Schh lets move on :-)
Yay the standard is falling into place! Soon our favorit players might play Dolby Vision!
baker99
Post by baker99 » Mon May 25, 2020 10:07 am
Exciting times :) I'm as desperate as everyone for a binary but willing to wait while these excellent developers sort everything out. It's been sad seeing such a collaborative and friendly thread become distracted by other things, keep up the great work and we are here when you need testers.
Post by RESET_9999 » Mon May 25, 2020 11:10 am
tr000 wrote:
Mon May 25, 2020 2:01 am
Ah, I see. Does that output Profile 7?
yes dual layer profile 7 DV
Redhawk2000
Post by Redhawk2000 » Mon May 25, 2020 11:56 am
So are we saying there is now reasonable hope (expectation) that an htpc could be used within a few months?
steffenmanden
Post by steffenmanden » Mon May 25, 2020 12:21 pm
Currently it's for Android players there is being played with code, but the code can be moved elsewhere afterwards if people integrate it! Its all about pushing your favorite players as soon as the standard is in place!
Last edited by steffenmanden on Mon May 25, 2020 12:54 pm, edited 1 time in total.
steffenmanden
Post by steffenmanden » Mon May 25, 2020 12:22 pm
I think it just got misunderstood :)
One week and its going!
siriusbox
Post by siriusbox » Mon May 25, 2020 1:03 pm
Only if the device is licensed by Dolby, and the hardware also supports it.
Post by SamuriHL » Mon May 25, 2020 1:49 pm
The htpc side requires a few things. A splitter, a renderer, and a decoder that all support Dolby vision. With a standard out of the way the splitter could be done. The renderer is a bit more challenging. Usually we'd ask madshi to add support to madvr but he's just working on the envy release. Still, there are other renderers out there and maybe one of them could add support. That leaves the decoder. Here's where things get a little interesting. Gaming in the pc has apparently been looking at Dolby vision support. Nvidia has had beta support for some time now and if you look at the very latest Intel driver support you will see Dolby vision is part of that release. I've no idea what's involved in making that work or if it's even possible, but these things are out there now.
All this is to say that Dolby vision on an htpc is not currently doable but isn't out of the realm of possible.
tr000
Post by tr000 » Mon May 25, 2020 1:50 pm
HTPC’s have always been listed in Dolby's DV docs. I wonder what, if any, official implementation plans they have/had.
tr000
Post by tr000 » Mon May 25, 2020 1:53 pm
Theoretically it shouldn't be that hard. I wonder if anyone has found a way to at least trigger EDID to send a Dolby Vision signal to activate the logo on a TV from a PC. AFAIK no one has done this. If it can be done on what is essentially an Android phone with an HDMI output there is no reason it shouldn't be able to be done on PC.
Post by SamuriHL » Mon May 25, 2020 1:57 pm
We have done so for calibration using an hdfury but that hardly counts. I'm wondering, however, if this change means they're trying to add Dolby vision support for things like Netflix streaming... if so that's interesting. Here's the relevant Intel driver release notes.
Highlights
Windows 10 May 2020 Update Ready
Intel Graphics Installer Changes5
This driver is WDDM 2.7 compliant and ready for the Windows 10 May 2020 Update. It introduces support for Dolby Vision and the new DirectX* 12 Shader Model 6.5 compiler on 7th Generation Intel Core processors or higher (Intel HD Graphics 610 or higher).
Post by shawnc22 » Mon May 25, 2020 2:20 pm
I’m not sure if it’s relevant, but there were some talks concerning the dolby vision app found in the microsoft store:
https://github.com/mpv-player/mpv/issue ... -605658877
DaMacFunkin
Post by DaMacFunkin » Mon May 25, 2020 6:10 pm
https://forums.plex.tv/t/dolby-vision-r ... /488390/13
This might give an insight into why refresh rate switching doesn’t work for DV on the shield.
Post by shawnc22 » Mon May 25, 2020 6:23 pm
It works in Plex, you just have to revert back to the old player, or use the new player + refresh rate app. Both players use exoplayer as the backend as far as I know so you're not losing much going between the two.
olevelo
Post by olevelo » Mon May 25, 2020 9:15 pm
The issue I was having with yusecope's exoplayer wasn't limited to DV. Exoplayer wouldn't switch refresh rates at all, whether it was playing DV content or not.
