1. Standard this next week most likelyolevelo wrote: ↑Sun May 24, 2020 11:27 pmI can use it NOW though. I already re-ripped half my DV collection with the current version of makemkv (I was already ripping some new ones anyway, so I started the process in hopes that it wouldn't change). Without using this, to watch any of those rips, I have to convert to TS first, and use double the storage. Who knows how long it will take 1. Matroska or whoever to decide on the standard. 2. Mike to implement it in MakeMKV so we have standard MKVs. 3. Players to implement playback support.steffenmanden wrote: ↑Sun May 24, 2020 11:12 pmYou know the apk you got is for a way that wont be used ?
And if you read my posts you could also see that coding should continue, but instead in a closed group meanwhile - test apks can be thrown all over, i dont care about those
So you would be in the exact same position, bit wouldnt have exposed the code to be used by others in the current not-standardized way.
But dont see the point in continuing the discussion! So lets leave it be! We can all agree that yusesope does good work.
It's your whole "closed group" mentality that I have an issue with. If what you really mean is "create a group that anyone with interest can join to help develop and test the implementation, and not share the information in this thread where it may be mistaken as official", then ok. But I haven't seen any postings of "here's the group". I've just seen you talking about how you're going to do everything in private, which to me goes against the whole concept of open source software.
Again, we're all on the same side and want the same end result. But walling yourself off to a few people doesn't really do anyone any good.
2. Straight after the standard is in place
3. As you can see Yusesope is already working on a version to have ready the exact second Mike releases.
So you would have a new version in a week most likely - but you wont avoid having to rerip all your movies! Will happen no matter what
And we are just talking the code while the standard is not in place
