My mistake, Asus BD-16D1H-U Pro
Re: My mistake, Asus BD-16D1H-U Pro
blodsbrro wrote: Sat May 23, 2020 3:19 pm I'm quite confused as well. As mentioned by the OP, the MK firmware below is available for the 16D1H-U (which I have).
ASUS-BW-16D1H-U-A204-WM01001-211901041044
However my drives information is showing this below. Should I be using the ASUS_ODD_FW_Changer_(Modified) tool to flash the above firmware. I'm not interested in UHD, just enabling support for Libredrive if possible for this player. Am I missing something here ? Or should I be using a Pioneer flasher with another MK firmware ?
OS device name: /dev/rdisk3
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E104
Serial number: QLDL154056WL
Firmware date: 2017-06-14
Highest AACS version: 63
Status: Might be supported in future, keep fingers crossed
Drive platform: Pioneer RS8600
Firmware version: ID71
You cannot flash that drive. It is a Pioneer. LibreDrive does not currently work on any Pioneer drives.
