Unable to Save Log
koberulz
Unable to Save Log
Post by koberulz »
I have the log set to save in [username]/.MakeMKV, which is the default location.
However, in the log readout at the bottom of the program it lists it as saving at C:\Users\[username]/.MakeMKV, which is wrong. And thus, no log file is created.
Browsing for the folder just gets me the same result, with the incorrect slash. Even selecting a different folder still insists on saving it into the incorrect [username]/.MakeMKV path. So it's impossible to set the log location.
Re: Unable to Save Log
Post by d00zah »
That's just the way that msg prints... even when the path is syntactically correct on the 'General' tab in preferences. If the log is not being saved, it's typically a permissions issue. No other messages?
koberulz
Post by koberulz »
There are no other relevant messages in the log section, no. There is also no log file. There used to be one, though.
Post by d00zah »
I just tested this, but misread the location msg. Log is written to C:\Users\[username]/MakeMKV_log.txt, so up one level from the defined Data directory.
