Option to deselect Dolby or DTS core
polymath
#1 Post by polymath » Wed May 20, 2020 8:31 pm
When I rip a Blu-ray with lossless audio (DTS-HD MA or Dolby TrueHD) I generally want to extract only that lossless audio track and not the lossy "core" that it contains. MakeMKV's default is to extract both the lossless and the lossy as separate tracks, so for discs with many titles I have to step through them all and deselect the lossy audio individually for each.
A very useful feature and one that would save a lot of time would be an option to automatically deselect the lossy portion whenever lossless audio is present.
Re: Option to deselect Dolby or DTS core
#2 Post by d00zah » Wed May 20, 2020 8:50 pm
MakeMKV Preferences > General tab > Expert mode (exposes the Advanced tab)
https://www.makemkv.com/forum/viewtopic.php?f=10&t=4386
For example, my rule looks like this (entered on the Advanced tab):
-sel:all,+sel:(favlang|nolang),-sel:mvcvideo,=100:all,-10:favlang
I choose ALL tracks in my preferred language. You'll need to tweak yours per the guide.
polymath
#3 Post by polymath » Wed May 20, 2020 9:15 pm
Thanks very much, I was unaware of this. I'll play with it.
polymath
#4 Post by polymath » Thu May 21, 2020 8:25 pm
I revised your setting (which seems to be the out-of-the-box default) to this:
-sel:all,+sel:(favlang|nolang),-sel:core,-sel:mvcvideo,=100:all,-10:favlang
and it does just what I want. Thanks again.
#5 Post by d00zah » Thu May 21, 2020 8:44 pm
polymath wrote: Thu May 21, 2020 8:25 pm I revised your setting (which seems to be the out-of-the-box default) to this:
It was a fresh install, so I'm not surprised. Thanks for the reminder to finish transferring settings.
Happy to help.
koberulz
#6 Post by koberulz » Fri May 22, 2020 10:58 am
As I understand it, Dolby TrueHD doesn't have an accessible core the way DTS-HD MA does.
I know if I only rip the lossless track, on playback with Emby my LG TV has to re-encode the audio for TrueHD but can direct play the DTS core.
#7 Post by Woodstock » Fri May 22, 2020 1:07 pm
koberulz wrote: Fri May 22, 2020 10:58 am As I understand it, Dolby TrueHD doesn't have an accessible core the way DTS-HD MA does.
MakeMKV will usually pull the core out of a TrueHD track as a separate AC3 track. At least, that's what handbrake sees when I go to encode a title with TrueHD tracks.
koberulz
#8 Post by koberulz » Fri May 22, 2020 4:11 pm
Yes, but the OP in this thread is asking how to make it not do that.
