Buster Keaton Shorts
fmantek
Post by fmantek »
I am trying to put them into the modern times, but i am unsuccessful with 2 out of 4 blurays. Disc 1 and 4 exhibit the same problem, i can rip the video just fine, but as soon as i include the audio track (imagine.. that audio track...) i get rip errors, pasted below. Is this a bad mastering? (sorry have no normal bluray player to even see if the bluray is ok, currently assuming this is not a disc error - have not had a bad disc on delivery for such a long time...).
Any hints for this?
BUG: Code 3221225664 at 266L9_:?HCenQ;[b:213134952
Saving 1 titles into directory E:/Video/BUSTER KEATON DISC 1 using profile 'AAC-stereo' from file 'C:\Program Files (x86)\MakeMKV/appdata.tar:aac-st.mmcp.xml'
DEBUG: Code 0 at -)z6VSgqHN_H|`WxNE&G:121263360
DEBUG: Code 1 at &o}wM6/twkL4p8.9:121264165
DEBUG: Code 0 at K4M/?$T|dbX;omT7RsRD]:29400140
DEBUG: Code 1 at .?vdHC-OM;:I1eG4:213131663
DEBUG: Code 0 at .?vdHC-OM;:I1eG4:121265062
DEBUG: Code 0 at wCSHk;=~}Y`ze{E'$X}_:29393286
AV synchronization issues were found in file 'E:/Video/BUSTER KEATON DISC 1/BUSTER KEATON DISC 1_t00.mkv' (title #1)
AV sync issue in stream 1 at #0 : converting audio from 24bps to 16bps
Failed to save title 0 to file E:/Video/BUSTER KEATON DISC 1/BUSTER KEATON DISC 1_t00.mkv
0 titles saved, 1 failed
DEBUG: Code 3221225664 at 266L9_:?HCenQ;[b:213134952
koberulz
Re: Buster Keaton Shorts
Post by koberulz »
Which Keaton Shorts set is this?
webeing
Post by webeing »
I am experiencing exactly same issue with Buster Keaton Eureka Masters of Cinema Region 2 Blu Ray set.
I use Bitdefender Antivirus and have added the exe files of MakeMKV to be exceptions. I unprotected the folder I was writing to. I then tried creating a new folder on the desktop so that it wasnt protected.
Disc 1: The only title copying across is an introduction to Coney Island.
Disc 2: All titles have copied across although it is not the original sound track, but a commentary one.
Havent tried rest yet, but assuming its the same as original post.
Windows 10 user, running MakeMKV as an Administrator.
How can you change the audio to be correct?
How can disk 1/3 be copied?
Many thanks
fmantek
Post by fmantek »
It's the Master of Cinemas Series, "The complete short 1917-1923"
Frank
koberulz
Post by koberulz »
Ah. Not the one I have then.
