Blu-ray copy complete but 0 titiles saved (log posted)
The Flying Penguin
I'm trying to backup an original Blu-ray disc but after the progress bar completes, I get an error message. I have never had any problems before. For some reason this disc keeps failing. I have even tried ripping only the DD track and no subtitiles but it made no difference (log of this attempt below). This is under Ubuntu 10.04 32bit.
Btw, love your product so far and plan to purchase soon!
Debug log started at Tue Nov 16 00:42:42 2010 , written by MakeMKV v1.6.2 linux(x86-release)
Using 380928KB for read cache.
001005:0000 MakeMKV v1.6.2 linux(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /home/masterchief/MakeMKV_log.txt
DISCID=22A8255475E91B432E109F097AD8ED5A8B3E7901
003307:0000 File 00001.mpls was added as title #0
003307:0000 File 00007.mpls was added as title #1
003025:0000 Title #00002.m2ts has length of 77 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00003.m2ts has length of 49 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00005.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00006.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #00008.m2ts has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 1 titles into directory /media/2577E34070D64552/gone
001003:0020 DEBUG: Code 7 at Wqbm;jPOE.WfTFa;{q,9:121264050
001003:0020 DEBUG: Code 0 at ATl%+VrS8~+T$nq8x3a+w:29397449
001003:0020 DEBUG: Code 0 at @z6[nsj~7zt'$^X!0@&:121263751
FS ID=V_MPEG4/ISO/AVC C=1
TI=ZeNpjZGBg6O1w4WCAgoI0aa50BuJBAzsDgwULgj4Qy8DwkpmBgQkiLcAIJABJuwZn
C_00000=ZeNpbwNLwfnMKA8N/KGCAgv9ogBkoxgTEelAaBGZCKCZOAyDJmvFuY5E4kMHLxsjJyQJkNTAwOAAxg2jiLMGC6wwMzEiI7QtQQiaRwf7kQnEOzfh/W7UaUBRwrYDIyz/KcD3EFY5TnvsL0OymqVjkAZLJNro=
005003:0000 Failed to save title 0 to file /media/2577E34070D64552/gone/title00.mkv
005004:0080 0 titles saved, 1 failed
setarip_old
Re: Blu-ray copy complete but 0 titiles saved (log posted)
Hi!
What's the title of your problematic commercial Blu-ray?
The Flying Penguin
I made sure to post the log and then went on to forget to post the title of the movie lol.setarip_old wrote:Hi!
It's Gone In 60 Seconds.
setarip_old
A release that old should not be problematic. Have you tried cleaning the disc?
- Contact:
A known problem that will be corrected in a next version.
servocrow
when is the next version due? expected ETA
setarip_old
@The Flying Penguin
Hi!
If only to provide cold comfort, I just finished using the Windows version of MakeMKV to successfully process both a full disc and a movie-only version of "Gone in 60 Seconds" - so I guess "mike admin's" statement regarding a "known problem" is specifically applicable to the Linux version of MakeMKV...
Hi!
- Contact:
No, it's likely that you have a different edition of this disc.setarip_old wrote:statement regarding a "known problem" is specifically applicable to the Linux version of MakeMKV...
setarip_old
@mike admin
Are you referring to the Region, or do you mean a different "flavor" (one disc versus two-disc, re-release, etc.)?No, it's likely that you have a different edition of this disc.
- Contact:
Either one - all is known that H264 video files are slightly different on these discs.
