yusesope
Post by yusesope »
shawnc22 wrote:
Sun May 17, 2020 3:16 am
Thanks for the hard work as always, yusecope! A quick question about mode 2 when used with FEL titles. Is the data in the enhancement layer merged somehow into the base layer, or is it simply discarded? And regardless, if the resulting BL+RPU track is meant to be profile 5, is there also an IPT color space conversion being done? If not, then wouldn't it produce some color oddities during playback when forced to a profile 5 file in tsmuxer?
When "mode 2" is used to process FEL titles, the Enhancement Layer is completely removed.
The tool also does not perform any color space conversion.
As I said in the past (referring to the files obtained in "mode 2"):
yusesope wrote:
Sat Feb 29, 2020 6:26 pm
...the Base Layer is non-standard (it has a different color space than the IPTPQc2/IPT one) as extracted from a Bluray disk.
It should appear better than an HDR stream (since metadata is dynamic and non-static) but will not reach its maximum splendor due to the lack of data contained in the EL layer.
The lack of this information, however, could lead, in some cases, to evident chromatic aberrations.
Not surprisingly, in my tool, "mode 1" is the default.
Owners of devices capable of playing only movies with dvhe.05 profile, however, would have had DVDFab as their only choice.
It seemed right to me to offer them a free alternative.
Post by shawnc22 »
yusesope wrote:
Sun May 17, 2020 9:59 am
Got it, thanks for the clarification! It seems to me that a FEL->MEL conversion, and maybe followed by a conversion to IPTPQc2/IPT color space if profile 5 is desired, is kind of the “holy grail” for maximizing compatibility across devices. I know the Shield has been playing FEL titles fine, but I’ve always wondered if it’s doing it correctly since only profile 4 MEL is supposedly supported. FEL->MEL does seem like a daunting task, but maybe not as impossible as it once looked according to mike here?
mike admin wrote:
Sat Apr 18, 2020 4:20 pm
2. Dolby engineering is sort of "straightforward". For years(!!!) we have discussed what a complex job would be to convert DV streams and how million dollar software and NDA specs are required. Outcome? Converting from double-PID to single-PID is a matter of prefixing a single byte per packet. And with Dolby patents released in December 2019 we now know entire DV RPU structure - MakeMKV currently detects MEL and FEL streams, and to do so it parses 90% of RPU unit. It is not that hard. So, with current knowledge, even the "impossible" task of converting double-layer FEL to single-layer MEL looks quite doable - not as trivial as prefixing a byte, but not an impossible task either - decode EL layer, render data, encode coefficients back with MEL parameters, profit. Code complexity - like any codec, similar to decoding an ac3 frame.
And as for the IPTPQc2 conversion, I know the colorspace is a dolby proprietary one, but maybe the conversation here is of some help:
https://github.com/mpv-player/mpv/issue ... -613134501
Epedemic
Post by Epedemic »
A few (stupid?) questions:
dvhe.04.06 is to be understood as a Dolby Vision (dv) HEVC (he) 10 bit 4K 24fps (06) file, with a 1080p MEL or FEL (04) right?
And dvhe.06.06 should not exist according to https://www.dolby.com/us/en/technologie ... levels.pdf ?
But as i generate 04.06 files using both the makemkv->eac3to->tsmuxer and yusesope's tool in default mode, and both play fine on my Shield 2019, i must be doing everything right?
However i found some files from another source in dvhe.06.06 which plays equally fine, so i really shouldn't give a damn, and assume both are good as long as they play, but with slightly different metadata tagging?
VictorLemon
Post by VictorLemon »
Hello, a question to see who can help me, when the movie is in several m2ts, how can I extract the BL and EL files to mount with the tool?
a greeting
Epedemic
Post by Epedemic »
VictorLemon wrote:
Tue May 19, 2020 1:08 pm
a greeting
eac3to will do that.
Post by shawnc22 »
Epedemic wrote:
Tue May 19, 2020 11:08 am
Profile 6 is a deprecated standard, so you're not going to find it in the latest dolby docs. The difference between 4 and 6 is in its backwards compatibility ID (SDR for 4 and HDR for 6). Purely specs-wise, the video tracks generated from yusecope's tool and makemkv should be either profile 6 or 7 since they are HDR10 compatible. But since most devices don't support profiles 6/7, they are forced to profile 4 in tsmuxer (either through an older version of tsmuxer or a modified nightly version). When playing back DV content on a supported device, the backwards compatibility ID doesn't matter, so it's not really a big deal to incorrectly label these files as 4 for the pure purpose of DV playback.
In terms of the Shield, yusecope has mentioned in the past that when exoplayer encounters an unsupported DV profile, it likely looks at the video stream and then chooses the best suitable supported profile to play the file. So for instance when it encounters a BL+EL+RPU track that's labeled profile 6 or 7, it will fallback to treating it as profile 4 and still play them just fine.
olevelo
Post by olevelo »
So are you saying that if we play back one of the profile 4 videos on a non-DV device we won't even get HDR10?
Epedemic
Post by Epedemic »
shawnc22 wrote:
Tue May 19, 2020 3:58 pm
Thanks :) That clarified a lot for me.
Post by shawnc22 »
olevelo wrote:
Tue May 19, 2020 4:15 pm
With a fully-compliant profile 4 video, no, I don't believe you will get even HDR10 on a non-DV device. Take the LG DV demo from here for example:
https://4kmedia.org/lg-dolby-comparison-uhd-4k-demo/
This file in mediainfo is listed as:
Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU
whereas the profile 4/6 files we have been generating is labeled as:
Dolby Vision, Version 1.0, dvhe.04.06, BL+EL+RPU / SMPTE ST 2086, HDR10 compatible
On my Xbox one X, the LG demo doesn't even trigger HDR, but the other files will. This then brings up the question whether devices are really looking at just the profile to determine playback capabilities or at the actual content of the video stream. This I honestly have no idea and could simply be a device-to-device question.
VictorLemon
I extract the BL and EL files through eac3to, the movie is Despicable Me (2010), to extract charge in eac3to the main mpls, since the movie is in several m2ts, it generates the BL and EL, I use the yusesope tool in its latest version and when the process is at 99.9% it gives me the following error.
Greetings
yusesope
Post by yusesope »
VictorLemon wrote:
Tue May 19, 2020 5:25 pm
Greetings
Don't worry, the file you got is complete (only one byte is missing).
The error is due to your input file: it is not complete at the end.
I will correct this in the future.
VictorLemon
yusesope wrote:
Tue May 19, 2020 5:44 pm
Greetings
yusesope
Post by yusesope »
shawnc22 wrote:
Sun May 17, 2020 2:20 pm
the problem is not the conversion of the color space.
The problem is understanding how to generate new RPU metadata without distorting the color correction/grading work done in post production and the entire vision of the director.
With what we've discovered, you could take a video shot on your cell phone and insert random RPU metadata.
The video would be reproduced by activating Dolby Vision but the colors would be completely wrong!
VictorLemon wrote:
Tue May 19, 2020 5:50 pm
You are welcome
deadchip12
Post by deadchip12 »
MastaG wrote:
Tue Mar 17, 2020 1:05 pm
For Dolby Vision + Atmos:
Here's my success story for Gemini Man 2019 which is a 60fps movie which plays much more fluent.
I'm using Fedora 31 Linux but I've also posted windows links
Tools:
- ffmpeg - compiled from latest git (Windows build: https://ffmpeg.zeranoe.com/builds/)
- yusesope - tool V3: https://www.makemkv.com/forum/viewtopic ... 335#p85413
- eac3to portable version with wine - https://www.videohelp.com/software/eac3to
- tsmuxer modified for DV by a5180007/justdan96 - compiled from his github https://github.com/justdan96/tsMuxer (Windows build: https://bintray.com/justdan96/tsMuxer/t ... UI-Nightly) (Original forum thread: http://forum.doom9.org/showthread.php?t=176668&page=31)
Use the latest nightly tsMuxerGUI from this link, it's more recent compared the one posted a few pages back! and a5180007 also added support for eac3 dolby digital plus! (only 5.1)
First I demux the original bluray (will only work if I compile the latest FFMpeg git from source):
ffmpeg -i bluray:/path/to/my/bluray -map 0:0 -c copy ./BL.hevc -map 0:1 -c copy ./EL.hevc -map 0:2 -c:a copy -strict -2 ./atmos.mp4
Now I have:
BL.hevc - Base Layer
EL.hevc - Enhanced Layer
atmos.mp4 - Dolby TrueHD Atmos audio
Now I use yusescope V3 tool to create a single layer DV file:
python src/bl_el_rpu_builder.py -bl ./BL.hevc -el ./EL.hevc -of gemini_dv.hevc -mode 1
Now I also have:
gemini_dv.hevc - Full movie Single Layer DV
Now I use eac3to Gui to convert the atmos.mp4 to a compatible truehd+ac3 track for use with TSMuxeR:
wine UsEac3To.exe
- Click Input File and select atmos.mp4
- Under Track Input and Output format change "ac3" to "thd+ac3" then click Add
- In the bottom click RUN CL and wait
When finished you will have a "atmos.mp4_.thd+ac3" file, rename this to "atmos.ac3"
Now launch justdan96's version of TsMuxerGUI then add your movie file: "gemini_dv.hevc" and audio file: "atmos.ac3".
So I have tried this method for Gemini man and Sonic 2019 and both of them freeze every 2 seconds during playback. My tv is lg oled c9. The files were stored in an external hdd connected to the tv via usb. All other souble layered dolby vision mp4 files created using the original method in the first post of this thread play fine. Maybe my tv can't properly play .ts file/single layered dolby vision file?
Epedemic
Post by Epedemic »
deadchip12 wrote:
Wed May 20, 2020 12:47 am
Tools:
Now I have:
Now I also have:
wine UsEac3To.exe
Well, i'm not sure, but it sounds like what my E6 did when i accidentially fed it a .mp4 with a Atmos thd+ac3 file renamed to .ac3 waaaay back.... My suggestion: Try with a clean ac3 file and see if that helps, and then figure out how to do a proper thd+ac3 track afterwards (or put both in and switch between them and see if one or both works)
