shawnc22 wrote: ↑Sun May 17, 2020 3:16 amThanks for the hard work as always, yusecope! A quick question about mode 2 when used with FEL titles. Is the data in the enhancement layer merged somehow into the base layer, or is it simply discarded? And regardless, if the resulting BL+RPU track is meant to be profile 5, is there also an IPT color space conversion being done? If not, then wouldn't it produce some color oddities during playback when forced to a profile 5 file in tsmuxer?
When "mode 2" is used to process FEL titles, the Enhancement Layer is completely removed.
The tool also does not perform any color space conversion.
As I said in the past (referring to the files obtained in "mode 2"):
Not surprisingly, in my tool, "mode 1" is the default.yusesope wrote: ↑Sat Feb 29, 2020 6:26 pm...the Base Layer is non-standard (it has a different color space than the IPTPQc2/IPT one) as extracted from a Bluray disk.
It should appear better than an HDR stream (since metadata is dynamic and non-static) but will not reach its maximum splendor due to the lack of data contained in the EL layer.
The lack of this information, however, could lead, in some cases, to evident chromatic aberrations.
Owners of devices capable of playing only movies with dvhe.05 profile, however, would have had DVDFab as their only choice.
It seemed right to me to offer them a free alternative.
