I used MakeMKV to transfer a Blu Ray. In the folder are many video files (it's a serie) and it looks, that every episode was two times copied. One time with ~6GB and one 5,9GB but same lengh.
Can someone please explain me, why this is and what is the difference?
Two times nearly the same file / movie?
- bluray.png (33.01 KiB) Viewed 11011 times
Re: Two times nearly the same file / movie?
Possibly different playlists for different regions, I see this on many releases.
For example, one playlist might be English/French/Spanish, and the second playlist would be English/Japanese.
There could be other reasons, but you haven't given us any details.
For better support, you should give the name of the disc, you could also post a comparison of one of the playlists as shown in MakeMKV, with all the details expanded.
It's Nikita The complete Series.
- 1.png (43.47 KiB) Viewed 10971 times
- 2.png (42 KiB) Viewed 10971 times
- 3.png (42.15 KiB) Viewed 10971 times
and the last screenshot (only can add three Attachments)
- 4.png (42.23 KiB) Viewed 10971 times
So yes, it appears to be exactly what I suggested, they have made different playlists for different regions or language selections, possibly depending on your Blu-ray player.
One set of playlists for English/French audio with one variety of subtitles.
One set of playlists for English/Japanese audio with a different variety of subtitles.
Using: ASUS BW-16D1HT 3.00
Thank you for the answer.
