olupome
#1
Post
by olupome » Mon May 18, 2020 6:51 am
Hi guys,
I just flashed my internal Asus BW-16D1HT with MK firmware version 3.10. Everything looks fine in MakeMKV:
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: SIK98F26A470
Bus encryption flags: 1F
Highest AACS version: 63
Firmware version: 3.10
but when I insert a disk, UHD or standard bluray, it doesn't spin and act like nothing was inserted. Did I miss something?
#2
Post
by Billycar11 » Mon May 18, 2020 8:03 am
olupome wrote: ↑Mon May 18, 2020 6:51 am
Hi guys,
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
you had to check before you flashed it not after take the drive out and check the build date
olupome
#3
Post
by olupome » Mon May 18, 2020 8:17 am
It says feb 2015. Damn, is that device just too old?
#4
Post
by Billycar11 » Mon May 18, 2020 8:26 am
olupome wrote: ↑Mon May 18, 2020 8:17 am
yup to old, you should have check before flashing the MT1939 you would have saved your drive its bricked now unless your pc does ide mode and dos flash
olupome
#5
Post
by olupome » Mon May 18, 2020 8:35 am
Haha I totally messed it up then. Thanks for your help. It's not that important anyway, it's in a pc I don't really use anymore.
ELECTRO_Boss
#6
Post
by ELECTRO_Boss » Mon Jun 15, 2020 7:01 pm
Let's say sombody stupid also flashed his way too old Asus BW-16D1HT to ASUS-BW-16D1HT-3.10-WM01601-211901041014 and it stopped working but his PC supports IDE-Mode and dos flash. What would be the way to go to debrick it?
#7
Post
by d00zah » Mon Jun 15, 2020 8:50 pm
ELECTRO_Boss wrote: ↑Mon Jun 15, 2020 7:01 pm
Ultimate UHD Drives Guide Updated 2020
Refer to section "NS40 Recovery Image:"
