olupome
Posts: 9 Joined: Mon Feb 01, 2016 7:29 pm
Post
by olupome » Mon May 18, 2020 6:51 am
Hi guys,
I just flashed my internal Asus BW-16D1HT with MK firmware version 3.10. Everything looks fine in MakeMKV:
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
Serial number: SIK98F26A470
Bus encryption flags: 1F
Highest AACS version: 63
Firmware version: 3.10
but when I insert a disk, UHD or standard bluray, it doesn't spin and act like nothing was inserted. Did I miss something?
Posts: 6029 Joined: Sun Aug 24, 2014 5:49 am
Post
by Billycar11 » Mon May 18, 2020 8:03 am
olupome wrote: Mon May 18, 2020 6:51 am
Hi guys,
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.10
you had to check before you flashed it not after take the drive out and check the build date
olupome
Post
by olupome » Mon May 18, 2020 8:17 am
It says feb 2015. Damn, is that device just too old?
Post
by Billycar11 » Mon May 18, 2020 8:26 am
olupome wrote: Mon May 18, 2020 8:17 am
yup to old, you should have check before flashing the MT1939 you would have saved your drive its bricked now unless your pc does ide mode and dos flash
olupome
Post
by olupome » Mon May 18, 2020 8:35 am
Haha I totally messed it up then. Thanks for your help. It's not that important anyway, it's in a pc I don't really use anymore.
ELECTRO_Boss
Posts: 2 Joined: Mon Jun 15, 2020 6:54 pm
Post
by ELECTRO_Boss » Mon Jun 15, 2020 7:01 pm
Let's say sombody stupid also flashed his way too old Asus BW-16D1HT to ASUS-BW-16D1HT-3.10-WM01601-211901041014 and it stopped working but his PC supports IDE-Mode and dos flash. What would be the way to go to debrick it?
Posts: 1716 Joined: Mon Jun 06, 2016 8:23 pm
Post
by d00zah » Mon Jun 15, 2020 8:50 pm
ELECTRO_Boss wrote: Mon Jun 15, 2020 7:01 pm
Ultimate UHD Drives Guide Updated 2020
Refer to section "NS40 Recovery Image:"
