BP50NB40
muffenboy2003
BP50NB40
Post by muffenboy2003 »
Is it possible to flash/crossflash this drive to be UHD compatible? I have been trying to flash it and it doesn't work.
Re: BP50NB40
Doubtful. It's too old of a design to be able to read UHD.
muffenboy2003
Re: BP50NB40
Darn, I saw someone post about doing it so I thought it might have been possible.
Re: BP50NB40
Check the manufacturing date; I've seen model numbers re-used for incompatible hardware. BUT! That model number on the LG site only says BDXL capable, 5 years ago...which isn't the same as UHD, which is at a higher density than the original BDXL.
Re: BP50NB40
muffenboy2003 wrote:
Sun May 17, 2020 10:26 pm
The BP50NB40 SVC:NB50 can be flashed to MK firmware. It can then also be cross-flashed to a BP60NB10 using my hybrid (HBD) firmware which will then allow UHD ripping.
Use the search function looking for "hybrid firmware".
muffenboy2003
Re: BP50NB40
I was trying this with both the modified asus flasher made for this and the other one. The Asus one gave me updating error 4 and the other one was stuck at 0% forever.
Re: BP50NB40
Mon May 18, 2020 2:04 am
You must flash the drive to BP50NB40_1.02-MK first before you can use the hybrid firmware.
muffenboy2003
Re: BP50NB40
I was trying to flash to DE_LG_BP50NB40-NB50_1.01_MK_HBD. That was giving me the error.
Re: BP50NB40
Mon May 18, 2020 2:29 am
That would have worked if your drive came with 1.01 but I'm pretty sure all the newer one's come with 1.02.
Glad you got it sorted!
jonghotti
Re: BP50NB40
Post by jonghotti »
We're very proud of Marty's Hybrid Firmware, ok speaking for myself only I am very proud of Marty Hybrid Firmware "We Speak Your Name".
