BP50NB40
muffenboy2003
BP50NB40
Post by muffenboy2003 »
Is it possible to flash/crossflash this drive to be UHD compatible? I have been trying to flash it and it doesn't work.
Re: BP50NB40
Doubtful. It's too old of a design to be able to read UHD.
muffenboy2003
Re: BP50NB40
Darn, I saw someone post about doing it so I thought it might have been possible.
Re: BP50NB40
Check the manufacturing date; I've seen model numbers re-used for incompatible hardware. BUT! That model number on the LG site only says BDXL capable, 5 years ago...which isn't the same as UHD, which is at a higher density than the original BDXL.
Re: BP50NB40
muffenboy2003 wrote: Sun May 17, 2020 10:26 pm Is it possible to flash/crossflash this drive to be UHD compatible? I have been trying to flash it and it doesn't work.
The BP50NB40 SVC:NB50 can be flashed to MK firmware. It can then also be cross-flashed to a BP60NB10 using my hybrid (HBD) firmware which will then allow UHD ripping.
Use the search function looking for "hybrid firmware".
muffenboy2003
Re: BP50NB40
I was trying this with both the modified asus flasher made for this and the other one. The Asus one gave me updating error 4 and the other one was stuck at 0% forever.
Re: BP50NB40
muffenboy2003 wrote: Mon May 18, 2020 2:04 am I was trying this with both the modified asus flasher made for this and the other one. The Asus one gave me updating error 4 and the other one was stuck at 0% forever.
You must flash the drive to BP50NB40_1.02-MK first before you can use the hybrid firmware.
muffenboy2003
Re: BP50NB40
I was trying to flash to DE_LG_BP50NB40-NB50_1.01_MK_HBD. That was giving me the error.
Re: BP50NB40
muffenboy2003 wrote: Mon May 18, 2020 2:29 am I was trying to flash to DE_LG_BP50NB40-NB50_1.01_MK_HBD. That was giving me the error.
That would have worked if your drive came with 1.01 but I'm pretty sure all the newer one's come with 1.02.
Glad you got it sorted!
jonghotti
Re: BP50NB40
Post by jonghotti »
We're very proud of Marty's Hybrid Firmware, ok speaking for myself only I am very proud of Marty Hybrid Firmware "We Speak Your Name".
