Libredrive version v6
jonghotti
Re: Libredrive version v6
Post by jonghotti »
And one more time in summary: any drive that contains the 1959 chip can be flashed with WH16NS60 firmware to take advantage of the speed improvements offered by LibreDrive 6.
This act of cross flashing however may break compatibility WITH other software packages due to them not supporting the UHD Official drives and furthermore you may break a drive's ability to burn discs (ASUS all models that are burners??)
Anything else? Oh slim drive lemme check that here.
jonghotti
Post by jonghotti »
macOS 10.15.4
BU40N slim drive unrestricted drive speed = NO
WH16NS60 = YES
Post by SamuriHL »
Is LibreDrive enabled at all on that slim drive?
jonghotti
Post by jonghotti »
SamuriHL wrote: Sun May 17, 2020 7:09 pm Is LibreDrive enabled at all on that slim drive?
Yes it is, and as Billy just pointed out Unrestricted Read Speed set to NO upon running MakeMK for the second time, all good.
Post by SamuriHL »
Yea that's good. I was asking because Mike said this was a pretty extensive change so we want to confirm all functionality not just the rip speed. I realize we're all hot for the rip lock but we gotta validate everything. :)
ImCoKeMaN
Post by ImCoKeMaN »
Is there any chance that we could have a configurable libredrive option with the "sleep bug" and "unrestricted read speed" maybe in advanced options? I'd be willing to move fast enough to avoid sleep bug for the benefit of faster UHD read.
syntax_error
Post by syntax_error »
V6 doesn't work on my WH16NS60. I don't know whether it matters or not, but the drive is connected to internal SATA port.
MakeMKV consumes the sdf.06f.bin just fine and the LibreDrive information looks correct to me, but for some reason it doesn't work. V5 works like a champ.
OS device name: /dev/sr0
Product: BD-RE WH16NS60
Revision: 1.02
Serial number: ***********
Highest AACS version: 68
Firmware version: 1.02
Disc Information
Label: MEN_IN_BLACK_INTERNATIONAL
Timestamp: 2019-08-07 17:15:26
Data capacity: 56.46 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
MakeMKV v1.15.1 linux(x64-release) started
DEBUG: Code 2399522818 at !Ko|V6~1>:Q>[Nj2M:213132399
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:2'
DEBUG: Code 0 at ZF2@*aqIu4mgMH0Yh:213130766
DEBUG: Code 0 at Z3bZeQqXT9X4>IGo:":29395195
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SG:dev_21:2'
DEBUG: Code 0 at Z3bZeQqXT9X4>IGo:":121263475
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SG:dev_21:2'
DEBUG: Code 1 at Z3bZeQqXT9X4>IGo:":29395195
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SG:dev_21:2'
DEBUG: Code 1 at Z3bZeQqXT9X4>IGo:":121263475
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SG:dev_21:2'
DEBUG: Code 2 at Z3bZeQqXT9X4>IGo:":29395195
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:2'
DEBUG: Code 0 at Z3bZeQqXT9X4>IGo:":29396552
DEBUG: Code 4 at Z3bZeQqXT9X4>IGo:":29394275
Downloading latest HK to /home/user/.MakeMKV ...
Saved AACS dump file as /home/user/.MakeMKV/MKB20_v68_Men_In_Black-_International_3645.tgz
DEBUG: Code 0 at Y"1_`~gBhucQ>oW*:29396092
DEBUG: Code 0 at Y"1_`~gBhucQ>oW*:29395172
Post by mike admin »
ImCoKeMaN wrote: Sun May 17, 2020 8:02 pm Is there any chance that we could have a configurable libredrive option with the "sleep bug" and "unrestricted read speed" maybe in advanced options? I'd be willing to move fast enough to avoid sleep bug for the benefit of faster UHD read.
It does not work like that, unfortunately. What we thought of a "sleep" bug is actually a "permanent lost sync on high speed" bug. The bug happens when drive speed reaches certain level (anything above default). We only noticed it happening after sleep because it was the only time drive spinned too fast. Recall, how the drive goes out of sleep - it briefly spins very fast and then stabilizes. So the cause for the bug is not the act of sleep, but the act of going out and briefly spinning too fast.
Enabling fast speed instantly triggers that very bug, without going to sleep state altogether.
Post by SamuriHL »
That's interesting that it only happens on UHD friendly drives and not official. They must have code in the firmware that handles that. Thanks for the explanation of what's happening!
syntax_error wrote: Sun May 17, 2020 8:15 pm V6 doesn't work on my WH16NS60. I don't know whether it matters or not, but the drive is connected to internal SATA port.
Same bug then, not limited to slim drives. Were you be able to "reset" the drive - power it off completely. For SATA drive that means either powering off the computer or unplugging drive power if your SATA controller supports hotplug.
so what do our pcs have in common
my pc is an nforce 430 chipset with nvidia sata controller in ide mode
amd phenom x4 945
gtx 760
6gb ddr 2
Bluntman
Post by Bluntman »
Well the read speed is impressive. However I did get some strange debug codes thrown. Ignore my dirty screen lol.
Yes I know it looks like crap but zoom in and it’s fine lol
Billycar11 wrote: Sun May 17, 2020 8:28 pmnvidia sata controller in ide mode
This guy was at fault.
jayper
Post by jayper »
Drive 1:
Product: BD-RE BU40N
Revision: 1.03
Highest AACS version: 72
Firmware version: 1.03
Unrestricted read speed: No
Drive 2:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.01
Firmware date: 2117-03-31 14:26
Bus encryption flags: 1F
Firmware version: 3.01
Tested out both of the above drives.
Did a full back-up of a BD on the Asus and a UHD back-up on the LG.
No issues to report here. I'll keep testing discs and will test out another drive later on. Thanks Mike.
mike admin wrote: Sun May 17, 2020 10:34 pm
Yeah it's kinda notorious for being weird
