Onward (2020) (US) UHD Fails to open
pjarvi
Post by pjarvi »
Dump file submitted.
Obviously it's a new release, so hopefully just need to wait for the key.
Movie purchased from Disney Movie Club.
This was the error message:
Using LibreDrive mode (v05 id=0FA242DD4D0B)
Saved AACS dump file as C:\Users\username/.MakeMKV/MKB20_v72_Onward_4D8C.tgz
DEBUG: Code 0 at A4|1O]oNyrw2.-zn:29396092
DEBUG: Code 0 at A4|1O]oNyrw2.-zn:29395172
Re: Onward (2020) (US) UHD Fails to open
Did you send the tgz file to svq@makemkv.com so that a key can be generated for it?
pjarvi
Post by pjarvi »
Yes, it's working now as of this morning! There are 3 titles, I'm hoping the 800 playlist is the correct one like the other Disney UHDs.
pjarvi
Post by pjarvi »
Damn, getting SCSI errors, gonna try exchanging the disc with Disney. I've got the ASUS BW-16D1HT drive.
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00058.m2ts' at offset '805109760'
Post by SamuriHL »
You cleaned it with a microfiber cloth, yes?
pjarvi
Post by pjarvi »
Yup, the bottom is pristine, I handle all my discs by the outer edge and inner circle. I cleaned it anyway and no dice. Also tried the other 2 playlists in MakeMKV. Same error at the same spot.
Post by SamuriHL »
That's unfortunate. it's another reason I keep 2 different drives.
pjarvi
Post by pjarvi »
Called Disney's help line this morning and have a mailing label coming in for exchange. Apparently. this is a problem with many Disney UHD's due to them stacking the UHD disc on-top of the Bonus disc. The UHD ends up moving around the spindle on top of the other disc and gets circular scratches from the label of the other disc. It's been happening to a lot of people with the Star Wars UHD's. Thankfully, I haven't had any problems with mine, just this one.
