Avatar Collectors Edition BD+ Error
Just got the latest avatar and use latest SVQ files but fails to decrypt. Its using AACS v19.
Re: Avatar Collectors Edition BD+ Error
Did you email the log and dump file as well? It's the best way to ensure they get them in a timely fashion.
Yes I submitted dump via email. Thanks
- Contact:
At last - a third BD+ update targeted at MakeMKV. No SVQ for now, please continue to send dumps.
The price of fame eh Mike?
I have a different error with the UK release, this one seems less drastic and I'm thinking maybe just a new SVQ is needed:
MakeMKV v1.6.2 linux(x86-release) started
Downloading latest SVQ(s) to /home/muzer/Huge/install/bdhaxx ...
Loaded 41 SVQ file(s)
Processing BD+ code, please be patient - this may take up to few minutes
Processing BD+ code using generic SVQ from builtin/00001.svq
Failed to process BD+ code using generic SVQ from builtin/00001.svq
Processing BD+ code using generic SVQ from builtin/00000.svq
Failed to process BD+ code using generic SVQ from builtin/00000.svq
Saved BD+ dump file as /home/muzer/Huge/install/bdhaxx/dump_Extended_Collector___s_Edition_Disc_1_B033C85BE0CE77CB.tgz
Failed to process BD+ code, please check http://www.makemkv.com/svq/ for updated program and SVQ files
Dump file attached.
Dump file attached.
Just got back from Target and now have this blu-ray as well, I have sent off another dump, hope it helps!
People posting their logs here: don't forget to email your dump files to svq@makemkv.com as well so they get them quickly.
Done and done - I knew there was something I forgot. I'm also posting the dump for disc 2 as well in case it's different (not disc 3, though). (My internet connection is crawling at the moment, which is why it isn't sent yet)
- Contact:
SVQ file is updated. We've got more dumps for disc 1 than for disc 2, please send the dump as usual if dsall.svq fails for you.
This appears to be working for disc 1 - I'll verify and then try for 2 + 3 when this has finished! Thanks a lot!
My USA Region A release now works.
Excellent work Mike.
@muzer
Am I correct in presuming that, since you've not posted back,Discs 2 and 3 are also okay?
