Supported Encryptions
aPotentialUser
What encryptions can the program get around - both for blu-ray and for dvd's? and what is still unsupported?
- Contact:
Re: Supported Encryptions
Program should be able to handle all DVD discs without any problems, even if region code is mismatched.aPotentialUser wrote:What encryptions can the program get around - both for blu-ray and for dvd's? and what is still unsupported?
Most Blu-ray discs can be opened, specifically discs that do not use BD+ protection and use MKB v7 and below. Program will either open the disc or tell why it could not be opened. Files produced from Blu-ray will not contain any subtitles or chapters. Again, program will explicitly tell if some feature is unsupported.
