LG WH16NS40 1.02 DE burning issues
Re: LG WH16NS40 1.02 DE burning issues
2-perf wrote: Sun May 17, 2020 2:39 am Would you mind explaining why you initially recommended 1.02 DE instead of 1.03 MK?
I'm sure you have a good reason and I certainly would be interested in knowing. :)
1.02de is more compatible with more rippers works with everything that supports UHD ripping.
1.03mk should but some ripper programs just blacklist by firmware number and say no not by actual compatibility
2-perf
Post by 2-perf »
Any example of those ripper programs that blacklist by firmware number?
Could we have went directly from 1.04 Official to 1.03 MK or an intermediate firmware would have been needed?
Thanks!!
2-perf wrote: Sun May 17, 2020 2:46 am Any example of those ripper programs that blacklist by firmware number?
Thanks!!
intermediate is needed for 1.04+
dvdfab blacklists possibly others to sell you the UHD drive tool for $109
2-perf
Post by 2-perf »
So we would have done the following?
WH16NS40 1.04-Stock --> WH16NS60 1.02-MK
then
WH16NS60 1.02-MK --> WH16NS40 1.03-MK
Is that it?
That seems odd but you're the man. :)
I mean, why an 1.04 Official would take a 1.02 MK from an other model but not 1.03 MK of the same model...
2-perf wrote: Sun May 17, 2020 2:53 am So we would have done the following?
then
Is that it?
that would work alot of ways to go about it.
if you on anything but 1.04 official you can go directly to whatever firmware you want no side grades necessary
2-perf
Post by 2-perf »
Ok, when you have a few minutes I'd like to know why the WH16NS60 1.02-MK can be used as an "intermediate" firmware before we can apply WH16NS40 1.03-MK.
It must have something special...? :)
2-perf wrote: Sun May 17, 2020 10:32 am Ok, when you have a few minutes I'd like to know why the WH16NS60 1.02-MK can be used as an "intermediate" firmware before we can apply WH16NS40 1.03-MK.
its only needed to get around the additional downgrade checks on 1.04+ flashing it for anything other then that is unnecessary
2-perf
Post by 2-perf »
Yes but what does WH16NS60 1.02-MK have WH16NS40 1.03-MK doesn't that makes it usable as an intermediate? Both are two MK firmwares.
2-perf wrote: Sun May 17, 2020 10:49 am Yes but what does WH16NS60 1.02-MK have WH16NS40 1.03-MK doesn't that makes it usable as an intermediate? Both are two MK firmwares.
it has the a work around for the additional downgrade checks that 1.03mk does not. i have not looked at it out of respect as Mike but i have had dreams of making a 1 and done firmware de and mk additional downgrade work around in one.
but that is not necessary now because the new makemkv flasher i have for my setup is all scripted
2-perf
Post by 2-perf »
Thanks for explaining!
I think I'm done with the questions. :)
Take care!
D
S.p.e.c.t.r.e.
Post by S.p.e.c.t.r.e. »
Billycar11 wrote: Sun May 17, 2020 11:00 am
You instructed to go from WH16NS40 1.04-Stock --> WH16NS60 1.02-MK
then --> WH16NS40 1.03-MK.
The Wh16ns60 is an upgrade to the WH16NS40 and does 8X instead of 6x read. If I stopped there instead of following up with the wh16ns60 1.03-MK...
1. Would I have 8X speed reading?
2. Would my drive be Libre enabled?
Post by SamuriHL »
Yes, and no sleep bug. It's recommended to stay on the ns60 firmware.
yes this ^ it was a rare case where on older fw he couldn't burn discs and needed anydvd comparability ns60 no work with ns60
S.p.e.c.t.r.e.
Billycar11 wrote: Fri Jun 26, 2020 1:22 am yes this ^ it was a rare case where on older fw he couldn't burn discs and needed anydvd comparability ns60 no work with ns60
So going from WH16NS40 1.04-Stock --> WH16NS60 1.02-MK, I should be okay to burn bluray and DVD disk, will be able to read UHD, and won't have to worry about sleep bug, and will get 8X reading capability, and will have libre drive enabled, when using makemkv to rip blurays and dvd's, correct?
If it doesn't work and I have to go to WH16NS40 1.03-MK, I go back down to 6x speed, still are able to rip blurays, and have libre drive enabled using makemkv, correct?
Last edited by S.p.e.c.t.r.e. on Fri Jun 26, 2020 1:40 am, edited 1 time in total.
Yes
And
Yes
