Anyone successfully burned BD-R with an LG WH16NS40 1.02 DE ?
2-perf
Post by 2-perf »
As the subject says, anyone successfully burned BD-R with an "LG WH16NS40 1.04" flashed to "LG WH16NS40 1.02 DE"?
I'd like to know if my new drive is faulty or if the "LG WH16NS40 1.02 DE" firmware is the reason why I get Write Errors.
Unfortunately, I didn't tried to burn BD-R with it (unflashed) when I got it Wednesday, I had Billycar11 flashing it almost right after I unboxed it.
Thanks guys!!
2-perf
Re: Anyone successfully burned BD-R with an LG WH16NS40 1.02 DE ?
Post by 2-perf »
Ok, I flashed my LG WH16NS40 1.02 DE back to the LG WH16NS40 1.03 Official and I can burn BD-R.
So, the LG WH16NS40 1.02 DE firmware flashed on a LG WH16NS40 1.04 December 2019 results in a drive that is unable to burn BD-R.
Tom_Neverwinter
Post by Tom_Neverwinter »
can you post the log from make mkv?
I have a burn issue as well and it tells me the drive or disc is dirty. However the disc is clean and seems to be a bug
2-perf
Post by 2-perf »
Hi, I'm not using MakeMKV but AnyDVD HD.
Please read this other post of mine :)
viewtopic.php?f=19&t=22205
Tom_Neverwinter
run makemkv... so we can see what you have...
is there a unique serial or change we need to look for.
do you have the same clean issue I have?
not run it to rip a disc...
