0 Titles Saved - The Lone Gunmen NTSC R1
therealjoeblow
#1 Post by therealjoeblow » Sun Nov 14, 2010 4:40 am
I get errors on most of the episodes in this set, they fail to save.
Once MakeMKV starts, it reads the file at <1x (0.1x, 0.2x), I hear the harddrive chunking for several seconds then it says 0 titles saved, 3 errors or however many episodes are on the disc.
On some of the discs (6 disc set) it saves one of the 3 episodes, but fails on most of them.
Not a disc problem, MKVMergeGui has no problem with these if I simply drag the vob files into it, it makes MKV's just fine.
I tried to rerip the discs to harddrive with DVDFab, and get exactly the same results.
These are backup discs with all protections already removed.
setarip_old
Re: 0 Titles Saved - The Lone Gunmen NTSC R1
#2 Post by setarip_old » Sun Nov 14, 2010 3:46 pm
@therealjoeblow
Hi!
Try processing your original, commercial discs using ONLY Make MKV directly (NO DVDFab, AnyDVDHD,k etc. running)
therealjoeblow
#3 Post by therealjoeblow » Sun Nov 14, 2010 4:56 pm
I'll just use MKVMerge GUI instead - it works and MakeMKV doesn't...
BTW, DVDFab 8's "MKV remux" feature also has no issue with these discs.
Whatever MakeMKV is doing, it's doing it wrong if it can't process simple unencrypted discs that other tools can...
The REAL Joe
crowfax
#4 Post by crowfax » Sun Nov 14, 2010 6:48 pm
therealjoeblow
#5 Post by therealjoeblow » Mon Nov 15, 2010 3:20 am
Nope.
Because I stand by my original opinion - MakeMKV is doing something fundamentally wrong if it can't extract simple MPEG2 video and AC3 audio and remux it from unencrypted discs, like any number of other tools can. There's nothing tricky about doing that, the techniques are well documented, and no number of log files are going to help if this tool is doing it all wrong from the get-go.
The REAL Joe
#6 Post by mike admin » Mon Nov 15, 2010 10:32 am
therealjoeblow wrote:Nope. Because I stand by my original opinion - MakeMKV is doing something fundamentally wrong if it can't extract simple MPEG2 video and AC3 audio and remux it from unencrypted discs, like any number of other tools can.
MakeMKV is supposed to do just that but apparently there is an error in MakeMKV. It's impossible to diagnose this particular error without log and IFO files.
