LINUX - ffmpeg - 4K HDR HEVC X265 - Plex
plittlefield
Re: LINUX - ffmpeg - 4K HDR HEVC X265 - Plex
Post by plittlefield »
A few weeks on and I have some tweaks to the script, which now includes 'max-cll' variables.
I will create a github at some point, but for now, here are the important parts...
# set main variables
TITLE="Movie Name (YEAR)"
INPUT="/home/user/${TITLE} UHD.mkv"
OUTPUT="/home/user/${TITLE} 4K ffmpeg 2 Audio.mkv"
# read hdr variables from source file
ffprobe -loglevel quiet -read_intervals "%+#2" -select_streams v:0 -show_entries side_data "${TITLE} UHD.mkv" | egrep -m 1 -A 10 'Mastering display metadata' | grep -v 'Mastering display metadata' >/tmp/variables.txt
ffprobe -loglevel quiet -read_intervals "%+#2" -select_streams v:0 -show_entries side_data "${TITLE} UHD.mkv" | egrep -m 1 -A 2 'Content light level metadata' | grep -v 'Content light level metadata' >>/tmp/variables.txt
source /tmp/variables.txt
cat /tmp/variables.txt
# ffmpeg transcode
ffmpeg -y -i "${INPUT}" -t 00:05:00 -hide_banner -stats -loglevel quiet -analyzeduration 100M -probesize 100M -max_muxing_queue_size 9999 -map 0:v:0 -map 0:a:0 -map 0:a:0 -vf "crop=3840:1600:0:280" -pix_fmt yuv420p10le -vcodec libx265 -preset slow -x265-params "keyint=60:bframes=3:vbv-bufsize=75000:vbv-maxrate=75000:colorprim=bt2020:transfer=smpte2084:colormatrix=bt2020nc:master-display='G("$green_x","$green_y")B("$blue_x","$blue_y")R("$red_x","$red_y")WP("$white_point_x","$white_point_y")L("$max_luminance","$min_luminance")':max-cll='"$max_content","$max_average"'" -crf 24 -force_key_frames "expr:gte(t,n_forced*2)" -c:a:0 copy -c:a:1 dca -ab 1509k -map_metadata -1 -metadata title="${TITLE}" -metadata:s:a:0 language=eng -metadata:s:a:1 language=eng -map_chapters -1 -sn -strict -2 "${OUTPUT}"
...please adjust as required.
I do a 5 minute test plus have dual audio for my current and future setup :-)
Enjoy.
Stay safe,
Paully
Solverz
Post by Solverz »
Sorry if this sounds obvious :lol:
But if I run that handy script, does it compress a 4k hdr mkv file? With acceptable quality?
plittlefield
Solverz wrote: Sat May 09, 2020 9:04 pm Sorry if this sounds obvious :lol:
Yes.
A typical UHD REMUX goes down from 40GB to about 8GB.
Paully
plittlefield
...and don't forget that 8GB size includes an extra audio track for MY tastes, so if you only wanted 1 audio track then that size would come down!
Paully
iXDanXi
Post by iXDanXi »
Hi all,
This seems like the best thread to ask, what would be the command line for ffmpeg to keep the 4k video untouched, take the first of multiple audio files but convert that hopefully lossless from dts to ac3 or any other lossless codec (any advice on a codec appreciated)
Thabks
https://ffmpeg.org/ffmpeg.html#toc-Examples-1
There are a lot of possible command combinations. You're essentially asking for conversion to FLAC if you insist on lossless. For me, I haven't "heard" a reason to move away from a decent lossy format, because my hearing is perfect anyway.
plittlefield
iXDanXi wrote: Thu May 14, 2020 3:44 pm Hi all,
Thabks
Wow, your ears must be good... because I find DTS absolutely amazing.
That aside, Dolby TrueHD found in most UHD's is lossless, at least according to mediainfo...
Audio #1
Duration                                 : 1 h 37 min
Bit rate                                 : 7 644 kb/s
Maximum bit rate                         : 9 270 kb/s
Stream size                              : 5.20 GiB (30%)
Number of dynamic objects                : 13
...so a straight acodec copy would be fine for you...
..which is, in fact, what part of my ffmpeg command line does!
Paully
plittlefield
plittlefield wrote: Sat Apr 25, 2020 9:36 am A few weeks on and I have some tweaks to the script, which now includes 'max-cll' variables.
A tweak to the readhdrvalues function, which strips out anything after the / in the ffprobe output...
function readhdrvalues () {
  echo "Reading HDR values..."
  echo $1
  ffprobe -loglevel quiet -read_intervals "%+#2" -select_streams v:0 -show_entries side_data "$1" | egrep -m 1 -A 10 'Mastering display metadata' | grep -v 'Mastering display
metadata' | sed 's/\/.*//g' >/tmp/variables.txt
  ffprobe -loglevel quiet -read_intervals "%+#2" -select_streams v:0 -show_entries side_data "$1" | egrep -m 1 -A 2 'Content light level metadata' | grep -v 'Content light lev
el metadata' | sed 's/\/.*//g' >>/tmp/variables.txt
  echo "...done."
Regards,
Paully
centuryx476
Post by centuryx476 »
I search the forum and found this excellent post.
I am doing hardware acceleration with these commands provided. Trying to encode 4K HDR HEVC, But I noticed something odd;
I am using -cq as a command and no matter what value I put in, the bitrate stays the same (At around 20,000) I can lower it all the way to 0 and it remains the same.
Has anyone noticed this ? Is this a bug ?
Edit:
I think I fixed it.
I have to include -maxrate and -bufsize
Now the -cq is working!
