Ultimate UHD Drives Flashing Guide Updated New Pioneer Flashing 2026
jonghotti
Re: Ultimate UHD Drives Guide Updated 2020
No 12.5mm UHD friendly drives no, adapters though yes
CZ Eddie
WH16NS60 on clearance at frys.com for $84.
https://www.frys.com/search?search_type ... Name=false
YMMV since Fry's is a string away from bankruptcy.
So whether you can get this delivered or not, IDK.
Amazon has the WH16NS60 for either $67 bare, or $172 bundled with software to play UHDs.
jonghotti
That's most likely a mistake in their system. I order them anytime they show stock anywhere and end up receiving a phone call or email shortly after (sadness)CZ Eddie wrote: Sat May 16, 2020 11:46 pm WH16NS60 on clearance at frys.com for $84.
**update** just got the call, lol
jonghotti
Um, no, you may have been looking at WH16NS40 sir.Woodstock wrote: Sun May 17, 2020 12:01 am Amazon has the WH16NS60 for either $67 bare, or $172 bundled with software to play UHDs.
Ah, yes, so it is the NS40, which came up as "Amazon's Choice" for people looking for the NS60...
MudydyDogs
My1xT
thanks for the guide. also kinda awesome that the cheapest desktop drive I could get was a BH16NS55 which I could flash pretty straight, now I just need some UHDBDs to actually go ham.
although another drive I have an SN-506BB is listed as being compatible with triple and quad layer around the internet, probably no patches possible tho, right?
Henning, Denmark
ASUS BW-12B1ST - can it be flashed?
I have had this drive for several years, but some time ago it just refused to read Blueray discs.
From what I can read on the many sites I have been through, it is likely something mechanical.
I do have this strange thing, where windows 10 does not see the drive as a Blueray drive:
Device SCSI\CdRom&Ven_ASUS&Prod_BW-12B1ST\4&15828421&2&020000 was not migrated due to partial or ambiguous match.
But do not think that is the reason, because I installed a new Windows 10 on the same copmputer, where this is not showing.
Makemkv does not see the Blueray disc in either.
CD's and DVD's work.
Then I stumbled over this forum, and got the firmware flash package, but it seems like nothing happens - I have had the flasher running for long periods without any result.
This should not be due to anything mechanical, so is it the old model, that cannot be flashed?
In ASOS ODD FW Changer (Modified):
FW selected: ASUS-BW-16D1HT-3.10-MK
0 : ASUS BW-12B1ST 1.03
Can someone guide me?
Even with what drive to buy next?
Brgds Henning / Denmark
https://makemkv.com/forum/viewtopic.php ... 99&p=91271Henning, Denmark wrote: Sun Jun 07, 2020 9:33 am ASUS BW-12B1ST - can it be flashed?
shadowripper
Billy are you still providing the remote firmware upgrades? I have a BD-RE BU40N Rev: A102.Any help would be much appreciated.
Thanks in Advance.
Thanks in Advance.
jonghotti
I am! alexcoluzzi32@gmail.comshadowripper wrote: Sun Jun 14, 2020 3:15 am Billy are you still providing the remote firmware upgrades? I have a BD-RE BU40N Rev: A102.Any help would be much appreciated.
Thanks in Advance.
borgman81
Is this a compatible drive?
ccateni
With the Archgon MD-8107S-U3-UHD, would I be able to flash it with software and the USB connected to my computer or would I not have to?
jonghotti
Yes, it is!
