New Errors
Moorthy88
New Errors
Post by Moorthy88 » Sat Nov 13, 2010 8:41 pm
MakeMKV is suddenly not converting my captured HD files, and coughs up an error message after encoding. It used to work flawlessly....
I capture HD vid (.TS) using my Hauppauge HDPVR and Arcsoft software.
I then use TSMuxer to create bluray format folders, and MakeMKV for the final .mkv file.
I've abbreviated the error log as the same line was repeating over and over.
(001003:0020 DEBUG: Code 108120000 at ]8P!K|/(]\$Wlh]G+Ip:213129984)
Any help is appreciated.
Moorthy88
Re: New Errors
Post by Moorthy88 » Sat Nov 13, 2010 8:46 pm
I don't know if this helps, but this is the message I get from TSMuxer. (See below)
I don't know if I had the "H.264 stream does not contain fps field" message before, when MakeMKV was working fine.
For what it's worth, the bluray folders created by TSMuxer, have always played just fine on my PC, even after I started receiving the MakeMKV errors.
SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net
Decoding H264 stream (track 1): Profile: Main@4.0 Resolution: 1920:1080i Frame rate: 29.97
H.264 stream does not contain fps field. Muxing fps=29.97
Decoding AC3 stream (track 2): Bitrate: 384Kbps Sample Rate: 48KHz Channels: 2
B-pyramid level 2 detected. Shift DTS to 3 frames
Processed 9000 video frames
Creation of Blu-ray playlist
Creation of Blu-ray stream info and seek index
Mux successful complete.
Muxing time: 24 sec
skittle
Re: New Errors
Post by skittle » Sun Nov 14, 2010 5:40 am
Side stepping the problem but why not just go straight from ts->mkv with 'eac3to'?
Moorthy88
Re: New Errors
Post by Moorthy88 » Sun Nov 14, 2010 1:47 pm
skittle wrote:Side stepping the problem but why not just go straight from ts->mkv with 'eac3to'?
I'd still like to solve the MakvMKV problem (I'm stubborn).
But that said, I'll download it and give it a go.
Thanks.
setarip_old
Re: New Errors
Post by setarip_old » Sun Nov 14, 2010 3:35 pm
@Moorthy88
Hi!
1) What, if anything, has been changed in either your hardware setup or installed programs since the last time things were working properly for you?
2) As an experiment, try processing a previously captured .TS file that you previously SUCCESSFULLY processed
Moorthy88
Re: New Errors
Post by Moorthy88 » Mon Nov 15, 2010 2:53 am
setarip_old wrote: 1) What, if anything, has been changed in either your hardware setup or installed programs since the last time things were working properly for you?
Nothing has changed. That's the frustrating part.
setarip_old wrote: 2) As an experiment, try processing a previously captured .TS file that you previously SUCCESSFULLY processed
I wish I still had one available to try. They're all gone.
Re: New Errors
Post by mike admin » Mon Nov 15, 2010 10:15 am
Thank you for posting the log. A known problem, will be corrected in a next version.
