smarter file naming
thetoad
smarter file naming
#1 Post by thetoad » Tue May 12, 2020 6:59 pm
Currently the default way of naming a file is <title>_t<track #>.mkv. The point of the _t<track #> makes sense as a default when you'd have many files otherwise named the same, but becomes annoying if one changes the name of the title but then also has to change the filename if one doens't want it (but one doesn't want to change the default in case one has titles of the same name).
So I think it be better to be slightly smarter. Only use the the track tagging in a filename if one is creating multiple files with the same title, but otherwise not.
thoughts?
thetoad
Re: smarter file naming
#3 Post by thetoad » Wed May 13, 2020 5:20 am
So I'm confused, per that description, I shouldn't getting _t## if my filenames would be unique without it, but I am.....
#4 Post by Woodstock » Wed May 13, 2020 12:39 pm
The rules do have a property of "if the file name would be unique without applying this rule, do not apply it". Actually, adding that could end up with the first file being left alone, then the second one wouldn't be unique so the rule would be applied.
thetoad
#5 Post by thetoad » Thu May 14, 2020 7:18 am
yea, figured that out. I think it be smarter to not have the _t## as part of the template, but to be smart and do an analysis of the the whole job and then decide to be consistent across all of them.
for my needs I just removed it from the template, but think its could be a little more user friendly.
Grauhaar
#6 Post by Grauhaar » Thu May 14, 2020 7:53 am
I have changed it to "{NAME1}{Title:+DFLT}{_ID-:SN}" to have the "SourceNumber ?" (MPLS or M2TS) instead of the title number (the title number is only a counter without any releationship to anything) in the name. Specialy for series it is an great enhancement to have the MPLS for the epiosde ordering in the name. The bad thing is, for DVDs, it is only one number (I think the VTS) which is enhanced by a sequence number to avoid duplicates.
Good Luck :)
