LG WH16NS40 1.04 to LibreDrive
2-perf
Post by 2-perf »
Hi, I just received my LG WH16NS40 NS50. It's a 1.04 manufactured on December 2019
I want it to be working with AnyDVD HD.
Can anyone provide me with a small explanation and download links as to how I should proceed for the flashing?
Please remember, it has to work with AnyDVD HD. :)
regards,
Danny
2-perf
Re: LG WH16NS40 1.04 to LibreDrive
Post by 2-perf »
My understanding is to use the LG V2 flasher "BH14NS40_N1.00-A4_patched.exe" and apply:
- ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin
reboot, then apply
- DE_flash_HL-DT-ST_BD-RE_WH16NS40_1.02_NS50.bin
reboot, done.
Is that it?
regards,
Danny
2-perf wrote: Wed May 13, 2020 8:08 pm Hi, I just received my LG WH16NS40 NS50. It's a 1.04 manufactured on December 2019
regards,
Danny
Just flash WH14NS40 1.04-MK then flash either WH16NS40 1.03-MK or DE WH16NS40 1.02 NS50 and you are done.
2-perf
Post by 2-perf »
Thanks MartyMcNuts,
What are the differences between flashing to WH16NS60 1.03-MK and DE WH16NS40 1.02 NS50.
Sorry, I keep reading the post "Custom firmware pack with LibreDrive patches" where there's an explanation of DE and MK firmwares but still, I don't really get the "goal" of both types.
Also, I have a post in front of me as I'm writing this where Billycar11 wrote (on May 08 2020), "just flash WH16NS60 1.02 mk and done" speaking about the LG WH16NS40 1.04. Why would he recommend using "WH16NS60 1.02 mk" when you are recommending "WH16NS60 1.03-MK"?
2-perf
Post by 2-perf »
Also, what are the benefit(s) of crossflashing from WH16NS40 to WH16NS60? Why go WH16NS60 1.02 MK instead of WH16NS40 1.02 MK?
Thanks for your patience.
2-perf wrote: Wed May 13, 2020 11:39 pm Thanks MartyMcNuts,
If you flash NS60 firmware to your drive, it will not work with AnyDVD HD.
DE = Downgrade Enabled. These were around before the MK firmware and had just a single byte changed in the firmware to enable downgrading. The exception to this is that the newer drive firmwares (1.04, 3.10, 3.11 etc) disabled downgrading again, therefore, in your case, it is necessary to flash 1.04-MK first to re-enable downgrading. The DE firmwares have LibreDrive enabled.
MK = Mike's created firmware, which is based on the newer firmware versions that had removed downgrade ability (and sometimes UHD capability). These firmwares also enable LibreDrive.
Hope this helps.
2-perf
Post by 2-perf »
Ok, why did you suggested to me to use "WH16NS60 1.03-MK" when I clearly mentioned twice in my original post that I want to use it with AnyDVD HD? Sorry, I don't want to arrogant at all, just asking as my English is far from being perfect and it might be related to some bad interpretation on my side.
"Just flash WH14NS40 1.04-MK then flash either WH16NS60 1.03-MK or DE WH16NS40 1.02 NS50 and you are done."
2-perf wrote: Thu May 14, 2020 12:32 am Ok, why did you suggested to me to use "WH16NS60 1.03-MK" when I clearly mentioned twice in my original post that I want to use it with AnyDVD HD? Sorry, I don't want to arrogant at all, just asking as my English is far from being perfect and it might be related to some bad interpretation on my side.
My bad. I meant WH16NS40 1.03-MK. Post edited.
2-perf
Post by 2-perf »
Ok! :)
Why do you recommend MK firmware at all, I was just on the phone with Billycar11 and he told me MK firmware don't work with AnyDVD HD.
Edit : He do not recommend*.
2-perf wrote: Thu May 14, 2020 1:10 am Ok! :)
That's not completely true. I have used a BH16NS55 with 1.04-MK and a BH16NS55 cross-flashed to ASUS 3.10-MK with AnyDVD and they worked fine. The NS60 firmware, whether MK or DE does not work with AnyDVD.
2-perf
Post by 2-perf »
Got it.
techman
Post by techman »
Total newbie so I get lost and confused easily. I have an LG WH16NS40 drive with the 1.04 rom and want to be able to do UHD copies of my Blu Rays. What do I need to do to make it work?
I do have AnyDVD installed.
Thanks in advance.
techman
Post by techman »
Where can I find the files needed to update the rom version to make my drive UHD friendly?
jonghotti
Post by jonghotti »
2-perf wrote: Thu May 14, 2020 2:08 amGot it.
Marty’s been known to not read the question fully before answering, there was that time a couple months ago where he tells a guy who clearly had just bough a 1939 to flash it with 3.10 guy got pissed, cursed us, and left never to be seen again.
jonghotti wrote: Tue May 19, 2020 1:37 am
Hey, I did read the question. I just made a typo. :)
