Blumhouse's Fantasy Island
davidm
Post by davidm »
Which one is the right mpls movie, there are 4 on the blu-ray Redbox version.
fidel
Re: Blumhouse's Fantasy Island
Post by fidel »
One version, 01:49:06 is the theatrical version and the other, 01:49:24 is the unrated version. The duplicate of each version matches the same segment map so I really can’t distinguish the differences between them. Hope that helps?
davidm
Post by davidm »
:D
fidel wrote:
Wed May 13, 2020 11:57 pm
jjslegacy
Post by jjslegacy »
anyone figure this out? The files appear to be 1k bigger which seems odd between the A and B file name
hvnphoto
Post by hvnphoto »
jjslegacy wrote:
Fri May 15, 2020 3:17 pm
It is exactly what fidel stated. One version is the Theatrical Version and the other is the Unrated Version. You can rip both if you can't decide which to keep.
noved
Post by noved »
fwiw, I've ripped all four(4) titles ...
 R_A (title09   800.mpls   24,776,681,579 bytes)
UR_A (title10   801.mpls   24,989,555,773 bytes)
 R_B (title11   802.mpls   24,776,683,006 bytes)
UR_B (title12   803.mpls   24,989,557,152 bytes)
There is a very small file length difference between the R_A and UR_A and R_B and UR_B mkv fles, 1,427 (A) and 1,379 (B) byte, respectively. Aside from that I can't find any track differences, in codecs, video/audio track lengths, available tracks (video, audio, subtitle, etc). Just as fidel noted and as far as I've seen digging into them, R_A == R_B and UR_A == UR_B in content and playback.
