THey live 4k uhdd
Jman5150
THey live 4k uhdd
Post by Jman5150 » Tue May 12, 2020 9:09 pm
didn't burn.....failed
this is what popped up after I opened it with the THEY LIVE DISK in the Drive
MakeMKV v1.15.1 darwin(x64-release) started
Debug logging enabled, log will be saved as /Users/JeffMorrissette/MakeMKV_log_2.txt
Optical drive "BD-RE ASUS BW-16D1HT 3.10d" opened in OS access mode.
DEBUG: Code 0 at ^W_MavfVOaQJdBrM:121275849
DEBUG: Code 0 at "!(ZroUs/<,UmdJAm:121263130
DEBUG: Code 1 at "!(ZroUs/<,UmdJAm:121263130
Evaluation version, 24 day(s) out of 30 remaining
Using LibreDrive mode (v05 id=0FA242DD4D0B)
DEBUG: Code 0 at ^W_MavfVOaQJdBrM:213135458
File 00000.mpls was added as title #0
File 00008.mpls was added as title #1
Title #00012.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00000.m2ts was added as title #2
Title #00011.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 24 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00025.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00024.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00023.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00027.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 3 titles into directory /Volumes/Untitled/they live
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '30632706048'
Error 'Posix error - Device not configured' occurred while reading '/dev/rdisk2' at offset '30632706048'
DEBUG: Code 1073741830 at oSP+L3tvNI@"0q07Ib:29394758
DEBUG: Code 2281701379 at oSP+L3tvNI@"0q07Ib:29394758
DEBUG: Code 0 at (A'N9Wk]@H?rSYv0^#IO:29395402
DEBUG: Code 0 at qs`4C$*kpw p:}MLI9},:29394068
DEBUG: Code 0 at (A'N9Wk]@H?rSYv0^#IO:29394459
DEBUG: Code 14957376 at (A'N9Wk]@H?rSYv0^#IO:29393286
DEBUG: Code 0 at 12n3M84.-Z~c`8wRW71Q/:29400140
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 0 to file /Volumes/Untitled/they live/They Live_t00.mkv
DEBUG: Code 0 at %*gFmb9-C3] H*i ):213135389
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00021.m2ts' at offset '0'
DEBUG: Code 0 at qs`4C$*kpw p:}MLI9},:121265706
DEBUG: Code 0 at (A'N9Wk]@H?rSYv0^#IO:213130145
DEBUG: Code 0 at (A'N9Wk]@H?rSYv0^#IO:121262233
DEBUG: Code 0 at (A'N9Wk]@H?rSYv0^#IO:29393286
DEBUG: Code 0 at Sw=WR6+Z2A :%0mZOn_V:213137091
DEBUG: Code 0 at %$4P&W?OM;\l}eqJ:213130559
DEBUG: Code 0 at 12n3M84.-Z~c`8wRW71Q/:29399864
DEBUG: Code 0 at %$4P&W?OM;\l}eqJ:121262555
DEBUG: Code 0 at ,pw<k\HkupDO`x6O}k:121269708
DEBUG: Code 0 at ,pw<k\HkupDO`x6O}k:121270007
Failed to save title 1 to file /Volumes/Untitled/they live/They Live_t01.mkv
Error 'OS error - (ipc/send) invalid destination port' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '0'
DEBUG: Code 0 at (A'N9Wk]@H?rSYv0^#IO:121262348
DEBUG: Code 0 at vpF}E|J.YZfav(,:213132767
DEBUG: Code 0 at vpF}E|J.YZfav(,:29397426
DEBUG: Code 65536 at ,pw<k\HkupDO`x6O}k:121264970
DEBUG: Code 0 at ,pw<k\HkupDO`x6O}k:121267155
DEBUG: Code 0 at ,pw<k\HkupDO`x6O}k:213137597
Failed to save title 2 to file /Volumes/Untitled/they live/They Live_t02.mkv
Encountered 35 errors of type 'OS X IPC Error' - see http://www.makemkv.com/errors/ipc/
0 titles saved, 3 failed
DEBUG: Code 2281701379 at =RA@ck-0X;DRc(zR:213134952
Re: THey live 4k uhdd
Post by Billycar11 » Tue May 12, 2020 10:01 pm
bad disc or drive. how has the drive done with other 4k discs?
