Is there a way to downgrade the firmware on a Buffalo BRUHD-PU3 from BU11 to BU10?
Re: BRXL-PT6U2VB is UDH-friendly NOW
Post by MartyMcNuts » Mon Feb 17, 2020 10:59 pm
bioteq wrote: Mon Feb 17, 2020 3:39 pm
planet1 wrote: Wed Jun 19, 2019 10:25 pm just wanted to report back that my Buffalo BRXL-PT6U2VB is a UHD-friendly device now
congrats on the upgraded drive, one question though - what updater did you use to get to bn11, I'm seeing only the 2.00 updater from Buffalo which you linked earlier, not sure if this contains what I need?
Do I even need to update or do I just cross-flash to 1.03 from Mike?
Thanks for all the info!
You should use the modified ASUS flasher.
bioteq
Re: Is there a way to downgrade the firmware on a Buffalo BRUHD-PU3 from BU11 to BU10?
Post by bioteq » Mon Feb 17, 2020 11:10 pm
OK thank you, that's all I needed to know to get on with it.
I'll report back :)
planet1
Post by planet1 » Mon May 11, 2020 8:35 pm
bioteq wrote: Mon Feb 17, 2020 11:10 pm OK thank you, that's all I needed to know to get on with it.
I'll report back :)
So how did it go? My Buffalo drive really needed the LG LibreDrive FW (1.03) in order to read the UHD blu-ray discs.
jonghotti
Post by jonghotti » Mon May 11, 2020 8:42 pm
I always use the 1.00 BU40N firmware I wonder what the differences are.
I've got pre-flashed BU40Ns for sale in either the Buffalo or Vantec enclosures. Immediate shipping available.
pk3lee
Post by pk3lee » Thu Jul 02, 2020 1:02 am
Hi All,
I just get my Buffalo BRUHD-PU3 today, and I am using DVDFab UHD tool to downgrade it to BU10 by just a click, and completely successful. :D :D :D :D :D :D :D :D :D
Post by Billycar11 » Thu Jul 02, 2020 7:40 pm
pk3lee wrote: Thu Jul 02, 2020 1:02 am Hi All,
But you could have saved $75-$110 by following the guides here
rmccarroll
Post by rmccarroll » Sat Oct 31, 2020 3:50 am
planet1 wrote: Wed Jun 19, 2019 10:25 pm Hello,
just wanted to report back that my Buffalo BRXL-PT6U2VB is a UHD-friendly device now:
1. Crossflashing worked like a charm with this MK firmware
2. Device shows up as LibreDrive compatible:
3. and CAN FINALLY READ UHD-blurays:
@mike admin
Just in case you might be still interested in Buffalo firmwares, they released a new FW update tool [brdrive_fwupdater_200.exe], featuring:
a. Buffalo_BU40N_FW_Updater_2.01.exe
b. Buffalo_BH16NS58_FW_Updater_2.01.exe
It works!
- I used the firmware you linked
- I used the ASUS Crossflash exe if found on this site
Took all of 2 minutes.
Thanks planet1 for your post
Thanks makemkv.com forum contributors for your help
