MakeMKV does not show all tracks/titles
Buhli
Post by Buhli » Sun May 10, 2020 3:34 pm
Hi guys
I have an issue with MakeMKV and hope somebody can help me here.
At the moment I am using the newest version (v1.15.1, win x64) of MakeMKV.
The follow issue I had already with many different TV-Shows.
In this case, I try to rip from Smallvlle the first disc from season 1.
When I open the disc in VLC and have look to the titles, I can see there are total six titles and the menu. Please have a look to picture #1.
When I open the same disc in MakeMKV, I just see five titles. See picture #2
When I open the disc with MakeMKV in manual mode, I can see all six titles. See picture #3
If I type below in this manual mode window the number 1 and start to proceed, I got the same result as you can see in picture #2.
For me it is very important if I could use this title 1 [2:56:25], which contains all the episodes from the disk. Why? Because if I take title 2-5 I had sometimes the problem, the episodes was in the wrong order. Therefore, for me it is easier to split this one title later in four episodes as to check from every season from every TV-Show the order from the episodes.
I hope somebody can help me here.
Best regards
Buhli
Re: MakeMKV does not show all tracks/titles
Post by Woodstock » Sun May 10, 2020 5:13 pm
If you want to see every title on the disk, you must set your minimum title length to zero seconds. Default is 120, so the 9-second entry is skipped over.
Buhli
Post by Buhli » Sun May 10, 2020 6:58 pm
Hi Woodstock
Thank you for your quick reply.
This is not problem. I set already the minimum to 0 and you can see on the printscreens, this 9 sec title is there.
MakeMKV skipped the first title which goes almost three hours. This title contains all four episodes and because of this, its important for me.
I hope you can help me.
Best regards
Buhli
Post by mike admin » Sun May 10, 2020 8:38 pm
Use manual DVD mode http://www.makemkv.com/manualdvd/ to force MakeMKV to open this title.
Buhli
Post by Buhli » Mon May 11, 2020 4:01 am
Hi Mike
Thanks for your quick reply.
Yes, it works when I used the string "1:1-24".
At the end I want to use MakeMKV by command line (makemkvcon). Is it possible to start the manual mode by command line? Or can I change settings or create a profile which by defaul rip all the titles?
Best regards
Buhli
