WH14NS40 reads UHD, makes backup but...
The_AVB
Post by The_AVB »
I have this drive and it is from 2015. It has never been updated and does read UHD discs and makes a backup. I used MakeMKV 1.15.1 to make the backup. However, when I use Open files on the discatt.dat file it reads the file (Opening files on harddrive at F:/To Video File/Dark Phoenix (4K MKV) but fails to open disc.
Since I don't get a Volume key error and the disc is old enough to have a Volume key by now and it is a LibreDrive I'm at a loss of why I can't open the backup and rip it. Any thoughts?
OS device name: I:
Product: BD-RE WH14NS40
Revision: 1.00
Serial number: SIK9MF9HJ091
Firmware date: 2115-08-18 09:40
Highest AACS version: 70
Firmware version: 1.00
jonghotti
Re: WH14NS40 reads UHD, makes backup but...
Post by jonghotti »
MT1959 hardware running 1.00 are notoriously flaky. This is one of those that most likely won't accept a firmware update. All bets are off with this drive based my experiences with 3 others.
The_AVB
Post by The_AVB »
Thank you for the reply. If I was feeling brave or stupid enough what should I upgrade it to?
jonghotti
Post by jonghotti »
1.02 has traditionally been the stable, original UHD friendly firmware. It may not take a flash though. I got no love from either of the 1.00s I had, nothing but trouble.
The_AVB
Post by The_AVB »
Since it already makes a backup copy with no errors shown, are you saying that the really are errors in the backup that only appear when trying to open the discatt.day file?
The_AVB
Post by The_AVB »
Well I did get it to flash to 1.03 now I have to borrow another 4K disk to see if that changed anything.
The_AVB wrote: Sun May 10, 2020 12:50 pm Well I did get it to flash to 1.03 now I have to borrow another 4K disk to see if that changed anything.
1.03 from LG or 1.03mk?
The_AVB
Post by The_AVB »
1.03 from LG.
The_AVB wrote: Sun May 10, 2020 6:28 pm1.03 from LG.
yeah it wont read UHD anymore now
The_AVB
Post by The_AVB »
Will it take a reflash to a mk 1.02 or 1.03?
The_AVB wrote: Sun May 10, 2020 8:46 pm Will it take a reflash to a mk 1.02 or 1.03?
yeah but i recommend WH16NS60 1.02mk
jonghotti
Post by jonghotti »
Cross yer fingers!!
The_AVB
Post by The_AVB »
Well it did flash to WH16NS60 1.02 so now I have to get a disc to test it with. Thanks everybody for the help.
