The Hitman's Bodyguard UHD (Aussie Release)
Re: The Hitman's Bodyguard UHD (Aussie Release)
Post by SamuriHL »
SDF does NOT contained hashed keys. So the "manual update" is not a thing.
Thornback
Post by Thornback »
Right, good to know. So I just wait then?
Post by SamuriHL »
As long as your MakeMKV install is pulling the latest hashed keys when it scans the disc, then yes. If for whatever reason your MakeMKV install is NOT downloading the HK's then you have to solve that problem.
Thornback
Post by Thornback »
SamuriHL wrote: Fri May 08, 2020 11:20 pm As long as your MakeMKV install is pulling the latest hashed keys when it scans the disc, then yes. If for whatever reason your MakeMKV install is NOT downloading the HK's then you have to solve that problem.
How do I actually know for sure that it is downloading the latest hashed keys? All I have in the log is this:
MakeMKV v1.15.1 darwin(x64-release) started
Optical drive "BD-ROM Optiarc BD ROM BC-5550H B881d" opened in OS access mode.
Optical drive "BD-RE ASUS BW-16D1HT 3.01d" opened in OS access mode.
Using LibreDrive mode (v05 id=E064BA3E3F81)
Saved AACS dump file as /Users/.../Library/MakeMKV/MKB20_v61_The_Hitman's_Bodyguard_27BD.tgz
My apologies. I was getting confused with sdf and private_data.tar.
I wonder if something is blocking you getting updates? Are you using google's or duckduckgo's DNS? If not, try changing your DNS to either of those and see if that fixes the problem.
For me, the last hashed keys download was about 3 days ago.
Thornback
Post by Thornback »
I tried Google DNS just now (8.8.8.8 and 8.8.4.4) but to no avail. Also used my 4G hotspot which didn't work either.
How do you know that it was updated 3 days ago? Do you go by the _private_data.tar file modification date? Looks like that was updated on 2 May for me.
Should there be a line in the log telling you about downloading keys? As I don't even get an error code?
Post by SamuriHL »
Yes there should be an entry in the log when you scan a disc about downloading the hashed keys. Make sure the option to do so is checked in the settings.
Thornback
Post by Thornback »
I installed MakeMKV on another PC and got it to download the latest hashed keys. Still says 'unknown volume key' when trying to decrypt. So it appears it simply isn't available for this disc?
Post by SamuriHL »
For now. It can take a few weeks sometimes. Just keep trying periodically.
Thornback
Post by Thornback »
Still not working.
Thornback
Post by Thornback »
Looks like this disc is going to stay encrypted forever.
Off to pirate bay..
